Tuya Fingerbot / Cubetouch Bot Support
Is your Bluetooth integration on and working as expected? If not, try resetting/reloading the Bluetooth integration first, then go to TuyaBLE
the integration page for a while was not available via the integration page link. you can get the correct link if you go to this integration in HACS and from there you can press on documentation and get to the right respiratory.
here is the correct link :
an issue was opened about this problem and seems that it affect many , not just you or me (yes I got exactly the same problem).
The Author however seems to be not available for several months (hope all is ok as he is from Ukraine).
Update: seems that there is already proposed fix:
I havn’t tried yet to implement it.
Edit 2:
I have used the suggested fixes and simply changed the contecnt of those files inside the custom_components folder of the integration. after changing the content of the 2 files and restart - the integration works as regularly.
To apply that fix we need to manually download these files
Capture d’écran, le 2024-01-04 à 09.41.00
And replace them in custom_components->ble_monitor
Is that correct?
That is what I did. Kinda. I just copied and pasted the content of these files from the fix to those I already had in the “custom components” but I am sure that just replacing them with the fix would work also.
I got the same problem now. Worked to begin with, then it ran out of battery, went offline and I’m not able to reconnect now. Found any solution to your problem?
Hello, I have come this far because I recently acquired a cubetouch, the model that is supported, and my question is the following, would it be feasible to be able to control this without having Bluetooth on the machine?
I have the machine in a storage room and I do not have bluetooth, what I do have are several bluetooth proxies with Esp32, is it viable to make it work this way? There is some documentation about it.
Thank’s
Has anyone experienced this while trying to install TUYA BLE?
Config flow could not be loaded: {“message”:“Invalid handler specified”}
I experienced that issue and solved it as described here:
This does not work for me on last HA version, do you know how to fix it? it find the device but says the device is not registered.
after you did the registration and it complained about “device is not registered.” did you still get a non working device added?
if so this is what worked for me to get it to work just follow the instructions here to get the local key (on the bottom of the page)
https://community.home-assistant.io/t/get-local-key-tuya-since-june-2022/436399
and then open .storage\core.config_entries
find this and change out the local_key for the one you just collected
        "entry_id": "9b6a42446d74608d93f5698aeb3e90fb",
        "version": 1,
        "minor_version": 1,
        "domain": "tuya_ble",
        "title": "door unlock",
        "data": {
          "address": "DC:23:50:24:86:0E"
        "options": {
          "endpoint": "https://openapi.tuyaeu.com",
          "auth_type": 0,
          "access_id": "xxxx",
          "access_secret": "xxxxx",
          "username": "xxxxx",
          "password": "xxxxx",
          "country_code": "46",
          "tuya_app_type": "smartlife",
          "address": "DC:23:50:24:86:0E",
          "uuid": "51e6434394xxx",
          "local_key": "V>`O*xxxxxxxx",
          "device_id": "bf2f9065dd1523xxxx",
          "category": "szjqr",
          "product_id": "xhf790if",
          "device_name": "door unlock",
          "product_model": "CBTB3002",
          "product_name": "CUBETOUCH II"
        "pref_disable_new_entities": false,
        "pref_disable_polling": false,
        "source": "bluetooth",
        "unique_id": "DC:23:50:24:86:0E",
        "disabled_by": null
after that it just worked for me best of luck.
Hi everyone,
Using your wonderful job, I managed to have my cubetouch working, using a “esp32 BLE Proxy”.
First of all, thanks a LOT for this.
A question remain, I don’t know how I could have a “direct” button to activate them…
When trying to add them to my dashboard I have this :
So, I use “add to dashboard”. Home assistant suggestion is :
Capture d'écran 2024-05-27 042331
The only way I found to activate my cube is clicking on the button , the “log journal” appear :
and then I can activate my cube with the “push” button (appuyer) on the right.
Any chance to have a direct bouton?
Hope I explained it right… I’m french, as you can see. :slight_smile:
Hello @fff41,
Your message is perfectly easy to read, I’m french too (from Quebec).
You need to get the Push entity ID. Click on your Push entity:
Click on the gear icon to see below:
My Push entity is called button.fingerbot_vrc_push, copy yours in your pastebin
Then you can go to one of your dashboards, modify it, add a new button, and paste your entity ID
Is it working?
:champagne:
It worked ! thanks a lot :wave: :smile:
How do you factory reset the device?
I am curious how you had / have this working “not locally”. I have two fingerbots that work fine from the Smart Life app on my phone. I can connect them to Home Assistant via the (cloud) Tuya integration but they show up as ‘unavailable’. I am not surprised because they connect via Bluetooth, not WiFi like my other Smart Life devices. So how are you connecting to them? Is Tuya somehow using your phone’s Bluetooth?
I abandoned it some time ago so i dont remember details. I managed to add them to home assistant and it was working but as i said i abandoned all.
You can try zigbee finger bot. It does work but battery consumption is high. Also abandoned and looking for another solution.
I do have an alternative solution: Switchbot fingerbots. They are easily set up in HA using the SwitchBot integration.
However, I still have two Cubetouch fingerbots and it is frustrating that they work perfectly well from Smart Life but I cannot get them to work with HA.
I think i got them working using tuya integration. They were connected to some tuya hub i bought who knows when for who knows what.
One burned out, another broke so i bought zigbee version. But frequent unresponives and high battery consumption made me to abandon all.
I used it only for fireing up dishwasher and washing machine.
Dishwasher will very likely be replaced with wifi one and washing machine have no future plans for now.
Ah! That answers my question, but I don’t have one. I want to use ESP32 Bluetooth Proxies.
I tried to do something with bluetooth but didnt make it work. I managed to get some data out of it but it is just too much work and hassle.
If you have some other alternative better try that than fingerbot. It will work for a year maybe two at the most if you using it regulary and then you can trash it. At least that was in my case.
