Hello
i think this ist not 100% correct.
As mentioned here,
and as i understand all the ESP-thing, the “WB3S” can easyly be replaced by any ESP-12S Module which can be flashed with tasmota.
So remains the main question - also for myself - is there a way to get the combined IR an RF-Bridges work with tasmota.?
Esppecially the 433MHz & 315Mhz Version seems to be very interesting for having a long desired all-in-one solution.
Michael
Thank you @orange-assistant for your useful info. Atm there is an compiler error (API - Issue) for the Chip/Device. I contacted the developer. If this work it will be awesome.
First of all to answer your question: The API problem seems to be solved since one of the last updates.
I haven’t flashed it yet because of lack of time. My requirement is to have a self learning mode or a connection to an existing IR remote database (like tuya does) because I don’t want to program all my remote buttons separately.
