Since it is possible to flash Beken-Chips (in my case WB3S) with
ESP-Home or Tasmota I search for a good open source firmware in comparisen to the original Smart Life App (Tuya) to control and to easy teach IR-Devices.
What I love on the official Tuya Smart Life App it is direct hands on (pre teached remotes and easy learning mode). What I don’t like is that sub devices (and this is what tuya does: the gateway create subdevices) cannot be integrated - neither via the official Tuya integration nor via the HACS Tuya local Integration.
I want to open a discussion about ESP-Home Projects to control teachable IR-Remotes with the following requierements:
- Integratable: for sure integratable into Home Assistant
- Libraries: existing IR remote libraries (Samsung, LG, JVC, …)
- HandsOn: Easy teaching/ learning mode for new and unknown devices without be forced programming each button via ESP-Home environment (push IR button → give the button a name, done)
- Frontend: visual teaching maybe with pictures of the remotes
Some nice Projects:
- “Lernende Infrarot-Fernbedienung mit ESP32” (German). Advantage: The learned buttons are safed directly into the flash memory. The device works also without HA.
- Faking an IR remote control using ESPHome - #10 by Aihua. Disadvantage: all Buttons of remotes need to be programmed seperately / no easy learning function
- Visual IR. Disadvantage: no easy learning function
Would you guys share your projects?
