This one will react to a change that stays for 30’s
blueprint:
name: Sync TRV tempature
description: Sync external tempature sensor with TRV tempature
domain: automation
input:
ieeeaddressoftrv:
description: This is the address of the TRV found in your zigbee database example 0x459877fffe1f2e83
external_temp:
name: Select the external temp sensor
description: This will be your external temp sensor
selector:
entity:
domain: sensor
device_class: temperature
climate_name:
description: This will be the TRV it self in home assistant
selector:
entity:
domain: climate
alias: Calibrate badkamer_thermostat
description: ''
variables:
target_device: !input 'ieeeaddressoftrv'
climate_device: !input 'climate_name'
temperature: !input 'external_temp'
adjust: "{{state_attr(climate_device, 'current_temperature')}}"
- platform: state
entity_id: !input 'external_temp'
for: '00:00:30'
condition: []
- service: mqtt.publish
data_template:
topic: zigbee2mqtt/{{ target_device }}/set/local_temperature_calibration
payload_template: >-
{{states(temperature)|float(0) | round(1,'half') - (state_attr(climate_device,'current_temperature')|float(0) | round(1, 'half') - state_attr(climate_device,'local_temperature_calibration')|float(0) | round(1, 'half'))}}
