I am looking to help add support for this smoke detector into ZHA.
I found that it is supported by Zigbee2MQTT (https://zigbee.blakadder.com/Smart9_S9ZB-SA02.html, https://www.zigbee2mqtt.io/devices/TS0601_smoke.html)
Hopefully, it can be added quite easily to ZHA also.
<details><summary>Device signature</summary>
<p>
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0051",
"in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"manufacturer": "_TZE200_uebojraa",
"model": "TS0601",
"class": "zigpy.device.Device"
</p>
</details>
<details><summary>Device diagnostics</summary>
<p>
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.10.4",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Amsterdam",
"os_name": "Linux",
"os_version": "5.15.72",
"supervisor": "2022.10.0",
"host_os": "Home Assistant OS 9.2",
"docker_version": "20.10.17",
"chassis": "vm",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.2",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.82",
"zigpy-deconz==0.19.0",
"zigpy==0.51.3",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.2",
"zigpy-znp==0.9.1"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 43698,
"model": "TS0601",
"name": "_TZE200_uebojraa TS0601",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4417,
"power_source": "Battery or Unknown",
"lqi": 255,
"rssi": -27,
"last_seen": "2022-10-18T11:08:57",
"available": true,
"device_type": "EndDevice",
"signature": {
"endpoints": {
"1": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"active_coordinator": false,
"entities": [],
"neighbors": [],
"endpoint_names": [
"name": "SMART_PLUG"
"user_given_name": null,
"device_reg_id": "6083f6faff90d7bc03ce1dd8bf3135fd",
"area_id": "f94dff210e784ca9a49f31421a22d036",
"cluster_details": {
"1": {
"device_type": {
"name": "SMART_PLUG",
"id": 81
"profile_id": 260,
"in_clusters": {
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"unsupported_attributes": {}
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0xef00": {
"endpoint_attribute": null,
"attributes": {},
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0001": {
"attribute_name": "app_version",
"value": 67
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZE200_uebojraa"
"0x0005": {
"attribute_name": "model",
"value": "TS0601"
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
</p>
</details>
<details><summary>Additional Logs</summary>
<p>
#### Adding device log (tried to keep it as clean as possible)
[0x7B67:1:0x0b04]: async_update
[0x7B67:1:0x0b04]: Reading attributes in chunks: ['active_power', 'rms_current', 'rms_voltage']
[0x7B67:1:0x0b04] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=44, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7B67:1:0x0b04] Sending request: Read_Attributes(attribute_ids=[1291, 1288, 1285])
New device 0xaab2 (a4:c1:38:b7:87:51:44:76) joined the network
[0xaab2] Scheduling initialization
Tries remaining: 3
[0xaab2] Requesting 'Node Descriptor'
Tries remaining: 2
[0xaab2] Extending timeout for 0x2e request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.Broadcast: 15>, address=<BroadcastAddress.ALL_ROUTERS_AND_COORDINATOR: 65532>), dst_ep=0, source_route=None, extended_timeout=False, tsn=30, profile_id=0, cluster_id=19, data=Serialized[b'4\xb2\xaavDQ\x87\xb78\xc1\xa4\x80'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
Device 0xaab2 (a4:c1:38:b7:87:51:44:76) joined the network
[0xaab2] Canceling old initialize call
Received frame on uninitialized device <Device model=None manuf=None nwk=0xAAB2 ieee=a4:c1:38:b7:87:51:44:76 is_initialized=False> from ep 0 to ep 0, cluster 19: b'4\xb2\xaavDQ\x87\xb78\xc1\xa4\x80'
[0xaab2:zdo] ZDO request ZDOCmd.Device_annce: [0xAAB2, a4:c1:38:b7:87:51:44:76, 128]
Tries remaining: 3
Tries remaining: 2
[0xaab2] Extending timeout for 0x30 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=31, profile_id=0, cluster_id=32770, data=Serialized[b'.\x00\xb2\xaa\x02@\x80A\x11BB\x00\x00*B\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
Received frame on uninitialized device <Device model=None manuf=None nwk=0xAAB2 ieee=a4:c1:38:b7:87:51:44:76 is_initialized=False> from ep 0 to ep 0, cluster 32770: b'.\x00\xb2\xaa\x02@\x80A\x11BB\x00\x00*B\x00\x00'
[0xaab2:zdo] ZDO request ZDOCmd.Node_Desc_rsp: [<Status.SUCCESS: 0>, 0xAAB2, NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)]
[0xaab2:zdo] No handler for ZDO request:ZDOCmd.Node_Desc_rsp([<Status.SUCCESS: 0>, 0xAAB2, NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)])
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=32, profile_id=0, cluster_id=32770, data=Serialized[b'0\x00\xb2\xaa\x02@\x80A\x11BB\x00\x00*B\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
Received frame on uninitialized device <Device model=None manuf=None nwk=0xAAB2 ieee=a4:c1:38:b7:87:51:44:76 is_initialized=False> from ep 0 to ep 0, cluster 32770: b'0\x00\xb2\xaa\x02@\x80A\x11BB\x00\x00*B\x00\x00'
[0xaab2] Got Node Descriptor: NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)
[0xaab2] Discovering endpoints
Tries remaining: 3
[0xaab2] Extending timeout for 0x32 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=33, profile_id=0, cluster_id=32773, data=Serialized[b'2\x00\xb2\xaa\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
Received frame on uninitialized device <Device model=None manuf=None nwk=0xAAB2 ieee=a4:c1:38:b7:87:51:44:76 is_initialized=False> from ep 0 to ep 0, cluster 32773: b'2\x00\xb2\xaa\x01\x01'
[0xaab2] Discovered endpoints: [1]
[0xaab2] Initializing endpoints [<Endpoint id=1 in=[] out=[] status=<Status.NEW: 0>>]
[0xaab2:1] Discovering endpoint information
Tries remaining: 3
[0xaab2] Extending timeout for 0x34 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=34, profile_id=0, cluster_id=32772, data=Serialized[b'4\x00\xb2\xaa\x14\x01\x04\x01Q\x00\x01\x04\x04\x00\x05\x00\x00\xef\x00\x00\x02\x19\x00\n\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
Received frame on uninitialized device <Device model=None manuf=None nwk=0xAAB2 ieee=a4:c1:38:b7:87:51:44:76 is_initialized=False> from ep 0 to ep 0, cluster 32772: b'4\x00\xb2\xaa\x14\x01\x04\x01Q\x00\x01\x04\x04\x00\x05\x00\x00\xef\x00\x00\x02\x19\x00\n\x00'
[0xaab2:1] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=81, device_version=1, input_clusters=[4, 5, 61184, 0], output_clusters=[25, 10])
Unknown cluster 0xEF00
[0xAAB2:1:0x0000] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=54, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0xAAB2:1:0x0000] Sending request: Read_Attributes(attribute_ids=[4, 5])
[0xaab2] Extending timeout for 0x36 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=35, profile_id=260, cluster_id=0, data=Serialized[b'\x186\x01\x04\x00\x00B\x10_TZE200_uebojraa\x05\x00\x00B\x06TS0601'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
[0xAAB2:1:0x0000] Received ZCL frame: b'\x186\x01\x04\x00\x00B\x10_TZE200_uebojraa\x05\x00\x00B\x06TS0601'
[0xAAB2:1:0x0000] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=54, command_id=1, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0x0000] Decoded ZCL frame: Basic:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x0004, status=<Status.SUCCESS: 0>, value=TypeValue(type=CharacterString, value='_TZE200_uebojraa')), ReadAttributeRecord(attrid=0x0005, status=<Status.SUCCESS: 0>, value=TypeValue(type=CharacterString, value='TS0601'))])
[0xaab2] Read model 'TS0601' and manufacturer '_TZE200_uebojraa' from <Endpoint id=1 in=[groups:0x0004, scenes:0x0005, None:0xEF00, basic:0x0000] out=[ota:0x0019, time:0x000A] status=<Status.ZDO_INIT: 1>>
[0xaab2] Discovered basic device information for <Device model='TS0601' manuf='_TZE200_uebojraa' nwk=0xAAB2 ieee=a4:c1:38:b7:87:51:44:76 is_initialized=True>
Device is initialized <Device model='TS0601' manuf='_TZE200_uebojraa' nwk=0xAAB2 ieee=a4:c1:38:b7:87:51:44:76 is_initialized=True>
Checking quirks for _TZE200_uebojraa TS0601 (a4:c1:38:b7:87:51:44:76)
Considering <class 'zhaquirks.xiaomi.aqara.opple_switch.XiaomiOpple2ButtonSwitchFace2'>
Fail because endpoint list mismatch: {1, 2, 242} {1}
Considering <class 'zhaquirks.xiaomi.aqara.opple_switch.XiaomiOpple2ButtonSwitchFace1'>
Fail because endpoint list mismatch: {1, 2, 41, 42, 242, 51, 21, 31} {1}
Considering <class 'zhaquirks.xbee.xbee_io.XBeeSensor'>
Fail because endpoint list mismatch: {232, 230} {1}
Considering <class 'zhaquirks.xbee.xbee3_io.XBee3Sensor'>
Considering <class 'zhaquirks.tuya.ts0201.MoesTemperatureHumidtySensorWithScreen'>
Fail because device_type mismatch on at least one endpoint
Considering <class 'zhaquirks.smartthings.tag_v4.SmartThingsTagV4'>
Considering <class 'zhaquirks.smartthings.multi.SmartthingsMultiPurposeSensor'>
Considering <class 'zhaquirks.netvox.z308e3ed.Z308E3ED'>
Considering <class 'zhaquirks.gledopto.soposhgu10.SoposhGU10'>
Fail because endpoint list mismatch: {11, 13} {1}
'sensor' component -> 'RSSISensor' using ['basic']
'sensor' component -> 'LQISensor' using ['basic']
device - 0xAAB2:a4:c1:38:b7:87:51:44:76 entering async_device_initialized - is_new_join: True
device - 0xAAB2:a4:c1:38:b7:87:51:44:76 has joined the ZHA zigbee network
[0xAAB2](TS0601): started configuration
[0xAAB2:ZDO](TS0601): 'async_configure' stage succeeded
[0xAAB2:1:0x0000]: Configuring cluster attribute reporting
[0xAAB2:1:0x0000]: finished channel configuration
[0xAAB2:1:0x0019]: finished channel configuration
[0xAAB2:1:0x0000]: 'async_configure' stage succeeded
[0xAAB2:1:0x0019]: 'async_configure' stage succeeded
[0xAAB2](TS0601): completed configuration
[0xAAB2](TS0601): started initialization
[0xAAB2:ZDO](TS0601): 'async_initialize' stage succeeded
[0xAAB2:1:0x0000]: initializing channel: from_cache: False
[0xAAB2:1:0x0000]: finished channel initialization
[0xAAB2:1:0x0019]: initializing channel: from_cache: False
[0xAAB2:1:0x0019]: finished channel initialization
[0xAAB2:1:0x0000]: 'async_initialize' stage succeeded
[0xAAB2:1:0x0019]: 'async_initialize' stage succeeded
[0xAAB2](TS0601): power source: Battery or Unknown
[0xAAB2](TS0601): completed initialization
Error handling '_save_attribute' event with (a4:c1:38:b7:87:51:44:76, 1, 0, 4, '_TZE200_uebojraa') params: FOREIGN KEY constraint failed
Error handling '_save_attribute' event with (a4:c1:38:b7:87:51:44:76, 1, 0, 5, 'TS0601') params: FOREIGN KEY constraint failed
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=36, profile_id=0, cluster_id=2, data=Serialized[b'5\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
[0xaab2:zdo] ZDO request ZDOCmd.Node_Desc_req: [0x0000]
[0xaab2:zdo] No handler for ZDO request:ZDOCmd.Node_Desc_req([0x0000])
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.Broadcast: 15>, address=<BroadcastAddress.ALL_ROUTERS_AND_COORDINATOR: 65532>), dst_ep=0, source_route=None, extended_timeout=False, tsn=39, profile_id=0, cluster_id=54, data=Serialized[b'6\xb4\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-30)
[0xaab2:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_req: [180, <Bool.true: 1>]
[0x7B67:1:0x0b04]: failed to get attributes '['active_power', 'rms_current', 'rms_voltage']' on 'electrical_measurement' cluster: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=40, profile_id=260, cluster_id=61184, data=Serialized[b'\tp\x11\x00;@'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-28)
[0xAAB2:1:0xef00] Received ZCL frame: b'\tp\x11\x00;@'
[0xAAB2:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=112, command_id=17, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0xef00] Unknown cluster command 17 b'\x00;@'
[0xAAB2:1:0xef00] Received command 0x11 (TSN 112): b'\x00;@'
[0xAAB2:1:0xef00] No explicit handler for cluster command 0x11: b'\x00;@'
[0x6306](01MINIZB): Device seen - marking the device available and resetting counter
[0x6306](01MINIZB): Update device availability - device available: True - new availability: True - changed: False
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=41, profile_id=260, cluster_id=61184, data=Serialized[b'\tp\x11\x00;@'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-28)
[0xDD77](TRADFRI Signal Repeater): last_seen is 15602398.541951656 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xDD77](TRADFRI Signal Repeater): Update device availability - device available: False - new availability: False - changed: False
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=42, profile_id=260, cluster_id=61184, data=Serialized[b'\tp\x11\x00;@'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-28)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=43, profile_id=260, cluster_id=0, data=Serialized[b'\x08q\n\x01\x00 C\xe2\xff 1\xe4\xff \x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
[0xAAB2:1:0x0000] Received ZCL frame: b'\x08q\n\x01\x00 C\xe2\xff 1\xe4\xff \x00'
[0xAAB2:1:0x0000] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=113, command_id=10, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0x0000] Decoded ZCL frame: Basic:Report_Attributes(attribute_reports=[Attribute(attrid=0x0001, value=TypeValue(type=uint8_t, value=67)), Attribute(attrid=0xFFE2, value=TypeValue(type=uint8_t, value=49)), Attribute(attrid=0xFFE4, value=TypeValue(type=uint8_t, value=0))])
[0xAAB2:1:0x0000] Received command 0x0A (TSN 113): Report_Attributes(attribute_reports=[Attribute(attrid=0x0001, value=TypeValue(type=uint8_t, value=67)), Attribute(attrid=0xFFE2, value=TypeValue(type=uint8_t, value=49)), Attribute(attrid=0xFFE4, value=TypeValue(type=uint8_t, value=0))])
[0xAAB2:1:0x0000] Attribute report received: app_version=67, 0xFFE2=49, 0xFFE4=0
[0xAAB2:1:0x0000] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=113, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0x0000] Sending reply: Default_Response(command_id=10, status=<Status.SUCCESS: 0>)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=44, profile_id=260, cluster_id=10, data=Serialized[b'\x00r\x00\x07\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
[0xAAB2:1:0x000a] Received ZCL frame: b'\x00r\x00\x07\x00'
[0xAAB2:1:0x000a] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=114, command_id=0, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0xAAB2:1:0x000a] Decoded ZCL frame: Time:Read_Attributes(attribute_ids=[7])
[0xAAB2:1:0x000a] Received command 0x00 (TSN 114): Read_Attributes(attribute_ids=[7])
[0xAAB2:1:0x000a] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=114, command_id=<GeneralCommand.Read_Attributes_rsp: 1>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0x000a] Sending reply: Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x0007, status=<Status.SUCCESS: 0>, value=TypeValue(type=LocalTime, value=719406532))])
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=45, profile_id=260, cluster_id=0, data=Serialized[b'\x08s\n\xdf\xffB\x0f\xb5E\xe1*f\xb5E\xe1*\x13\xb6E\xe1*\x12'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
[0xAAB2:1:0x0000] Received ZCL frame: b'\x08s\n\xdf\xffB\x0f\xb5E\xe1*f\xb5E\xe1*\x13\xb6E\xe1*\x12'
[0xAAB2:1:0x0000] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=115, command_id=10, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0x0000] Decoded ZCL frame: Basic:Report_Attributes(attribute_reports=[Attribute(attrid=0xFFDF, value=TypeValue(type=CharacterString, value='�E�*f�E�*\x13�E�*\x12'))])
[0xAAB2:1:0x0000] Received command 0x0A (TSN 115): Report_Attributes(attribute_reports=[Attribute(attrid=0xFFDF, value=TypeValue(type=CharacterString, value='�E�*f�E�*\x13�E�*\x12'))])
[0xAAB2:1:0x0000] Attribute report received: 0xFFDF='�E�*f�E�*\x13�E�*\x12'
[0xAAB2:1:0x0000] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=115, command_id=<GeneralCommand.Default_Response: 11>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xC582](SYMFONISK Sound Controller): last_seen is 8058877.430959702 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xC582](SYMFONISK Sound Controller): Update device availability - device available: False - new availability: False - changed: False
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=46, profile_id=260, cluster_id=61184, data=Serialized[b'\tt\x02\x00>\x01\x04\x00\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-28)
[0xAAB2:1:0xef00] Received ZCL frame: b'\tt\x02\x00>\x01\x04\x00\x01\x01'
[0xAAB2:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=116, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0xef00] Unknown cluster command 2 b'\x00>\x01\x04\x00\x01\x01'
[0xAAB2:1:0xef00] Received command 0x02 (TSN 116): b'\x00>\x01\x04\x00\x01\x01'
[0xAAB2:1:0xef00] No explicit handler for cluster command 0x02: b'\x00>\x01\x04\x00\x01\x01'
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=47, profile_id=260, cluster_id=61184, data=Serialized[b'\tt\x02\x00>\x01\x04\x00\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=48, profile_id=260, cluster_id=61184, data=Serialized[b'\tt\x02\x00>\x01\x04\x00\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=49, profile_id=260, cluster_id=61184, data=Serialized[b'\tt\x02\x00>\x01\x04\x00\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=50, profile_id=260, cluster_id=61184, data=Serialized[b'\tt\x02\x00>\x01\x04\x00\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=51, profile_id=260, cluster_id=61184, data=Serialized[b'\tt\x02\x00>\x01\x04\x00\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=52, profile_id=260, cluster_id=61184, data=Serialized[b'\tt\x02\x00>\x01\x04\x00\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xAAB2), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=53, profile_id=260, cluster_id=61184, data=Serialized[b'\tu\x02\x00?\x0e\x04\x00\x01\x02'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-27)
[0xAAB2:1:0xef00] Received ZCL frame: b'\tu\x02\x00?\x0e\x04\x00\x01\x02'
[0xAAB2:1:0xef00] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=117, command_id=2, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0xAAB2:1:0xef00] Unknown cluster command 2 b'\x00?\x0e\x04\x00\x01\x02'
[0xAAB2:1:0xef00] Received command 0x02 (TSN 117): b'\x00?\x0e\x04\x00\x01\x02'
[0xAAB2:1:0xef00] No explicit handler for cluster command 0x02: b'\x00?\x0e\x04\x00\x01\x02'
</p>
</details>
