Did you try turning it off and on again?
Joking! Good luck with this!!
Here’s my firmware dump: backup.bin - Google Drive
Binwalk output:
tasty@TASTY-MINT:~/Projects/rkdeveloptool$ binwalk backup.bin
DECIMAL HEXADECIMAL DESCRIPTION
163856 0x28010 CRC32 polynomial table, little endian
688144 0xA8010 CRC32 polynomial table, little endian
1684936 0x19B5C8 AES S-Box
1689328 0x19C6F0 AES Inverse S-Box
1700464 0x19F270 CRC32 polynomial table, little endian
1711008 0x1A1BA0 LZO compressed data
1775735 0x1B1877 Android bootimg, kernel size: 1919249152 bytes, kernel addr: 0x5F6C656E, ramdisk size: 1919181921 bytes, ramdisk addr: 0x5700635F, product name: ""
1861291 0x1C66AB Base64 standard index table
2011648 0x1EB200 Flattened device tree, size: 7168 bytes, version: 17
2733512 0x29B5C8 AES S-Box
2737904 0x29C6F0 AES Inverse S-Box
2749040 0x29F270 CRC32 polynomial table, little endian
2759584 0x2A1BA0 LZO compressed data
2824311 0x2B1877 Android bootimg, kernel size: 1919249152 bytes, kernel addr: 0x5F6C656E, ramdisk size: 1919181921 bytes, ramdisk addr: 0x5700635F, product name: ""
2909867 0x2C66AB Base64 standard index table
3060224 0x2EB200 Flattened device tree, size: 7168 bytes, version: 17
3566976 0x366D80 DES SP1, little endian
3567232 0x366E80 DES SP2, little endian
3569152 0x367600 DES PC1 table
3569208 0x367638 DES PC2 table
3573792 0x368820 SHA256 hash constants, little endian
3590920 0x36CB08 Unix path: /lib/libtomcrypt/hash.c
4615552 0x466D80 DES SP1, little endian
4615808 0x466E80 DES SP2, little endian
4617728 0x467600 DES PC1 table
4617784 0x467638 DES PC2 table
4622368 0x468820 SHA256 hash constants, little endian
4639496 0x46CB08 Unix path: /lib/libtomcrypt/hash.c
5373952 0x520000 Android bootimg, kernel size: 4581171 bytes, kernel addr: 0x10008000, ramdisk size: 5652951 bytes, ramdisk addr: 0x11000000, product name: ""
5376000 0x520800 LZ4 compressed data
5419543 0x52B217 SHA256 hash constants, little endian
5426334 0x52CC9E AES S-Box
5426590 0x52CD9E AES Inverse S-Box
8952942 0x889C6E AES Inverse S-Box
8985650 0x891C32 AES S-Box
8994130 0x893D52 AES Inverse S-Box
9395113 0x8F5BA9 xz compressed data
9483197 0x90B3BD Base64 standard index table
9786950 0x955646 gzip compressed data, fastest compression, has header CRC, has comment: "", last modified: 1970-09-18 22:19:55 (bogus date)
9957376 0x97F000 gzip compressed data, maximum compression, from Unix, last modified: 2023-05-11 10:03:28
15613440 0xEE3E00 Flattened device tree, size: 72977 bytes, version: 17
15686656 0xEF5C00 PC bitmap, Windows 3.x format,, 480 x 480 x 8
28442624 0x1B20000 Squashfs filesystem, little endian, version 4.0, compression:xz, size: 24063118 bytes, 2100 inodes, blocksize: 131072 bytes, created: 2023-05-11 10:03:25
Can u dump again because your dump file is corrupt?
thx advance,
seaky
File backup.bin is corrupted. Only fist 0x1ffffff bytes valid.
I’ve re-downloaded backup.bin and it’s identical to what I dumped from my device.
tasty@TASTY-MINT:~/Projects/rkdeveloptool$ sha256sum backup.bin
eead5a7a2614284a7cea1d434cbbe027ed2be717b4ce3f9253c53af40c7577ac backup.bin
Not sure why you say it’s corrupted?
binwalk is able to extract some parts of the dump. The squashfs filesystem inside doesn’t seem to be extractable though.
binwalk is irrelevant it is just searching for signatures does not check the integrity. I extracted the partitions from backup and the rootfs_a which is the squashfs looks like corrupt and also the userdata partition contains only 0xCC.
I wanted to check the fs level of a “linux” based version.
thx,
seaky
Unfortunately that’s all I was able to dump. Now my panel doesn’t boot anymore so my best option will be to create a new image from scratch but I’m not sure how to do that. I think the stock firmware was using u-boot as the bootloader so I might start with that.
fwiw, I got some fitting buttons off aliexpress (https://www.aliexpress.com/item/1005004067514307.html (“3x4x2 Two Feet”)), if I ever need them for anything. I guess the circuit is anyways missing some pull-ups, so not sure if they would do anything at all
Of course it is! So frustrating.
The hardware inside these units is just different enough that it seems it would be impossible to create a single image for all t6e style units.
Really a shame, because the form factor is quite nice.
A faster SoC, more RAM, and open firmware would really make this a great, viable device - not just a trinket for experimentation.
I wish Chinese companies would put in that last 5% effort to make thier products great.
(Many do, China is capable of building good stuff, I feel like the Alibaba sales model is an incentive for shadyness)
Hi, the original firmware can only be downloaded from flash only from “Loader mode”, but original bootloader from tuya firmware is protected, and block export data from flash after 32M. Need to use a different loader. There is hope. I have received a working device and will try to extract the original firmware.
I have the TPP01-Z_V1.0.4 version with the same bootloader.
It’s blocked from downloading past 32MB as you said.
I was however able to fetch the boot.img and extract the DTB (using extract-dtb):
compatible = "tuya,smart-panel\0rockchip,rk3308";
It would be interesting to build a custom image, I think postmarketos would be perfect for this.
It is difficult to create alternative software without a schematic diagram of the device. An analysis of the original could help with this. Protection is present in many other recent Rocchips-based devices. They deleted the old versions of the binary files from the public. I plan to remove the flash memory from the device board and read it in the programmer.
True.
I also have the NSPanel Pro, and that does not have this protection.
It is also based on a slightly different soc, rockchip px30
Do you know what type of flash memory it is?
I have a programmer for SPI chips, but if it’s emmc i won’t be able to.
Yes, NSPanel Pro is made on a PX30 processor, the base operating system of which is Android and has 8Gb emmc flash memory on NSPanel board. Android does not have export protection, but on the contrary it is its basic function for backup. The type of flash memory can be viewed by disassembling the device. Some EMMC chips support SDIO programming mode, but not SPI. TPP01-Z_V1.0.X is built on an RK3308 processor for which linux is the base operating system. And although after downloading the device is detected via USB as Android compatible, in fact this is not the case.When trying to connect to the shell from windows, it asks for a password, and from linux it says that there is “no secret key”. TPP01-Z_V1.0.X has only 230MB of flash and 128MB of RAM onboard, it is very small to run Android8.
TPP01-Z_V1.0.4
My MOES-branded one has 256MB SPI flash (Dosilicon DS35Q2GA-IB), and 256MB DDR3L (esmt m15t2g16128a)
I agree, it’s not going to run android (well), but it’s quite capable of running Linux.
Since PostmarketOS is based on Alpine, i think it would be perfect.
Running a browser for displaying homeassistant might be difficult, but maybe we can use this Framebuffer browser by e1z0
It would be a fun platform to make framebuffer apps on, and the rk3308 seems to be quite capable, especially if we get gpu support.
The SPI chip (at least on my board) might need a hot-air station to get out, the datasheet (available here) looks like it has a big pad under the chip.
I don’t have a hot air station, so I probably won’t be able to unsolder it.
I would really appreciate it if you’re able to get a firmware dump!
Then maybe check this out… pmOS on a much more capable device, but one that still integrates nicely in the home.
There is such a project Welcome to ROC-RK3308B-CC-PLUS Manual — Firefly Wiki , there is a Linux build with QT desktop support for it. And there is GitHub - OSSystems/qt-kiosk-browser: Provides a simple but highly configurable browser for use on Kiosk devices ?ysclid=lulq1h5l6u168707923. If we can combine them, it will be very good.
I have recently fallen prey to this T6E scam also. I think I have worked it out. The actual T6E is properly made by Smatek, and is properly Android only.
But because the form factor is similar, many sellers list TPP01-Z products as T6E - the usual deceptive Aliexpress listing practice (copy and paste everything roughly in the same category, nevermind the accuracy).
The actual full name of TPP01-Z is T1E-TPP01-Z. This likely reflects the much lesser hardware used (T1E vs T6E).
I was able to get Aliexpress to resolve the issue by the way of refund (but it requires I send the unit back in a prepaid by Aliexpress envelope, which I haven’t done yet). I am trying to convince myself that one of my rooms can use this device even if it just has two buttons on the front page - you can use them to trigger a series of scenes using HA so it could probably do at least 4 actions if not more via HA.
I mean yes, partly
Some sellers, like Moes or others also sold “real” T6E devices, until they released their new version. So there was a time when you could get a “real” one from other sellers than Smatek.
I also did some research about that some time ago and stumbled over their Alibaba store. Sadly the minimum order is 5 or 12pcs and shipping costs are ridiculous. Understandable, as Alibaba is B2B, so…
I’m really also interested in the 6, 8 or even 10.1" display they have, but… way too expensive right now sadly: Tuya Android Panels - SMATEK-Home Automation Smart Control expert
Here are there Alibaba links if somebody cares:
- T6E: Smatek Wireless 4'' Eu Smart Home Touch Panel Screen Control Switch Kit (black) - Buy Smart Home Touch Panel,Smart Home Kit,Touch Screen Home Appliance Control Product on Alibaba.com
- 6": Tuya 6 Inch Smart Home Touch Screen Control Panel With Knob Dimming Home Smart Home Control Panel S8e - Buy Zigbee Hub Gateway,Smart Touch Switches For Home Automation,Touch Screen Smart Wall Switch Product on Alibaba.com
- 8": Smart Building Touch Screen Switch 8 Inch Smart Knob Panel Items For Apartments Home Automation T8e-eu - Buy Touch Screen Switch smart Items For Home electric Home Product on Alibaba.com
- 10": Best Selling 10" Full House Control Panel Device Wifi Zigbee Home Automation Controller Hub Smart Gateway - Buy Smart Zigbee Gateway,Wifi Zigbee Hub,10" Full House Control Panel Product on Alibaba.com
Also @AndyW1, @feitingen and all the others involved: Thanks for all your work here!! If I can help somehow by testing things out or soldering/desoldering things on the Panel: Let me know
I’m just not really into the software side of those embedded systems ![]()
Hi all! A complete dump of a brand new device right out of the box. It is read by the T48 programmer. It is not suitable for firmware with RockChips utilities. TPP01-Z_V1.0.x — Яндекс Диск . It can be programmed back using the T48 programmer without disassembly flash from board by using a special zond. https://aliexpress.com/item/1005005448080665.html?spm=a2g2w.orderdetail.0.0.20034aa6rlKsN5&sku_id=12000033137757687
