I got myself 2 of these Tuya smoke detectors.
Since the HA Tuya integration can not support smoke detectors (due to missing support in the Tuya API) I tried flashing one of these using tuya-convert, then flashed tasmota, downgraded to the 7.x tasmota-minimal and then flashed esphome with this config:
substitutions:
devicename: esp_smoke_01
upper_devicename: Smoke 01
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret esphome_wifi_ssid
password: !secret esphome_wifi_password
# enable the fallback hotspot
ap:
ssid: $devicename
password: "qwe12345"
captive_portal:
api:
password: !secret esphome_api_password
ota:
password: !secret esphome_ota_password
logger:
baud_rate: 0
text_sensor:
- platform: version
binary_sensor:
- platform: status
uart:
- id: com_1
rx_pin: GPIO1
tx_pin: GPIO3
baud_rate: 9600
tuya:
[20:14:13][I][app:101]: ESPHome version 1.15.0-dev compiled on Jun 2 2020, 20:13:42
[20:14:13][C][wifi:415]: WiFi:
[20:14:13][C][wifi:283]: SSID: [redacted]
[20:14:13][C][wifi:284]: IP Address: 192.168.2.222
[20:14:13][C][wifi:286]: BSSID: [redacted]
[20:14:13][C][wifi:287]: Hostname: 'esp_smoke_01'
[20:14:13][C][wifi:291]: Signal strength: -61 dB āāāā
[20:14:13][C][wifi:295]: Channel: 1
[20:14:13][C][wifi:296]: Subnet: 255.255.255.0
[20:14:13][C][wifi:297]: Gateway: 192.168.2.1
[20:14:13][C][wifi:298]: DNS1: 192.168.2.1
[20:14:13][C][wifi:299]: DNS2: (IP unset)
[20:14:13][C][uart_esp8266:071]: UART Bus:
[20:14:13][C][uart_esp8266:073]: TX Pin: GPIO3
[20:14:13][C][uart_esp8266:076]: RX Pin: GPIO1
[20:14:13][C][uart_esp8266:078]: Baud Rate: 9600 baud
[20:14:13][C][uart_esp8266:079]: Bits: 8
[20:14:13][C][uart_esp8266:080]: Parity: NONE
[20:14:13][C][uart_esp8266:081]: Stop bits: 1
[20:14:13][C][uart_esp8266:085]: Using software serial
[20:14:13][C][logger:175]: Logger:
[20:14:13][C][logger:176]: Level: DEBUG
[20:14:13][C][logger:177]: Log Baud Rate: 0
[20:14:13][C][logger:178]: Hardware UART: UART0
[20:14:13][C][status:034]: Status Binary Sensor 'Smoke 01_status'
[20:14:13][C][status:034]: Device Class: 'connectivity'
[20:14:13][C][version.text_sensor:015]: Version Text Sensor 'Smoke 01_firmware_version'
[20:14:13][C][version.text_sensor:015]: Icon: 'mdi:new-box'
[20:14:13][C][captive_portal:169]: Captive Portal:
[20:14:13][C][web_server:131]: Web Server:
[20:14:13][C][web_server:132]: Address: esp_smoke_01.local:80
[20:14:13][C][ota:029]: Over-The-Air Updates:
[20:14:13][C][ota:030]: Address: esp_smoke_01.local:8266
[20:14:13][C][ota:032]: Using Password.
[20:14:13][C][api:095]: API Server:
[20:14:13][C][api:096]: Address: esp_smoke_01.local:6053
[20:14:13][C][wifi_signal.sensor:009]: WiFi Signal 'Smoke 01_Wi-Fi_Signal'
[20:14:13][C][wifi_signal.sensor:009]: Unit of Measurement: 'dB'
[20:14:13][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[20:14:13][C][wifi_signal.sensor:009]: Icon: 'mdi:wifi'
[20:14:13][C][tuya:023]: Tuya:
[20:14:13][C][tuya:026]: Configuration will be reported when setup is complete. Current init_state: 0
[20:14:13][C][tuya:027]: If no further output is received, confirm that this is a supported Tuya device.
Also tried GPIO13 and 15. NO go.
Itās sort of usable, because pressing the test button, connects to wifi, status changes to ON and therefore is useable as a smoke detector in HA.
It would be a lot better if it would also report battery status when pressing the test buttonā¦
When pressing the test-button for +5 seconds, it LED starts flashing fast and will remain connected to Wifi for flashing firmware. It works fast, reliable and perfect!
If anyone knows how to get the few remaining bits and pieces working, please post them here
