A blueprint for Tuya’s TS004F 4-button wireless switch.
blueprint:
name: Zigbee2MQTT - Tuya 4-Button Scene Switch TS004F
description: Automate your Tuya 4-Button Scene Switch (TS004F) via Zigbee2MQTT. Link - https://www.zigbee2mqtt.io/devices/TS004F.html
domain: automation
input:
switch:
description: Tuya 4-Button Wireless Switch
selector:
entity:
domain: sensor
integration: mqtt
button_one_short_press:
name: Button 1 - Single Press
description: Action to run on button 1 (bottom-left) single press
default: []
selector:
action: null
button_one_hold:
name: Button 1 - Hold
default: []
selector:
action: null
button_one_double_press:
name: Button 1 - Double Press
default: []
selector:
action: null
button_two_short_press:
name: Button 2 - Single Press
description: Action to run on button 2 (lower-right) single press
default: []
selector:
action: null
button_two_hold:
name: Button 2 - Hold
default: []
selector:
action: null
button_two_double_press:
name: Button 2 - Double Press
default: []
selector:
action: null
button_three_short_press:
name: Button 3 - Single Press
description: Action to run on button 3 (top-right) single press
default: []
selector:
action: null
button_three_hold:
name: Button 3 - Hold
default: []
selector:
action: null
button_three_double_press:
name: Button 3 - Double Press
default: []
selector:
action: null
button_four_short_press:
name: Button 4 - Single Press
description: Action to run on button 4 (top-left) single press
default: []
selector:
action: null
button_four_hold:
name: Button 4 - Long Press
description: Action to run on button 4 (lower-left) long press
default: []
selector:
action: null
button_four_double_press:
name: Button 4 - Double Press
default: []
selector:
action: null
source_url: https://gist.github.com/whalelion/5f19317ea530687a768ed2c34218cbc4
mode: single
max_exceeded: silent
variables:
command: "{{ trigger.payload }}"
topic: "{{ trigger.topic }}"
switch_name: !input "switch"
deviceName: "{{ state_attr(switch_name, 'friendly_name') }}"
- platform: mqtt
topic: zigbee2mqtt/+/action
- choose:
- conditions:
- "{{ topic.split('/')[1].replace('/', '') == deviceName.split(' ')[0]
sequence:
- choose:
- conditions:
- "{{ command == '1_single' }}"
sequence: !input "button_one_short_press"
- conditions:
- "{{ command == '2_single' }}"
sequence: !input "button_two_short_press"
- conditions:
- "{{ command == '3_single' }}"
sequence: !input "button_three_short_press"
- conditions:
- "{{ command == '4_single' }}"
sequence: !input "button_four_short_press"
- conditions:
- "{{ command == '1_double' }}"
sequence: !input "button_one_double_press"
- conditions:
- "{{ command == '2_double' }}"
sequence: !input "button_two_double_press"
- conditions:
- "{{ command == '3_double' }}"
sequence: !input "button_three_double_press"
- conditions:
- "{{ command == '4_double' }}"
sequence: !input "button_four_double_press"
- conditions:
- "{{ command == '1_hold' }}"
sequence: !input "button_one_hold"
- conditions:
- "{{ command == '2_hold' }}"
sequence: !input "button_two_hold"
- conditions:
- "{{ command == '3_hold' }}"
sequence: !input "button_three_hold"
- conditions:
- "{{ command == '4_hold' }}"
sequence: !input "button_four_hold"
- Short press
- Double press
- Long press (5 seconds)
It’s a copy of Z2M - TS004F Tuya 4-Gang Switch blueprint with the following additions.
- The button names were wrong in the original blueprint.
Button 1 - Left Bottom
Button 2 - Right Bottom
Button 3 - Top Right
Button 4 - Top Left - This blueprint follows the order
Button 1 Single Press
Button 1 Long Press
Button 1 Double Press
Button 2 Single Press
Button 2 Long Press
Button 2 Double Press
The original blueprint sometimes had inconsistencies in naming convention such as:
Button 1 Long Press
Button 2 Hold
Button 3 Long Press
Notes:
- A friendly name has to be set for the button in Z2M
2. The name cannot contain any spaces or special characters, if it does, the automation won’t work.
