Hi everyone,
This is a blueprint for the Tuya 4-Gang switch, TS004F edition. This will not work for TS0044.
blueprint:
name: Zigbee2MQTT - Tuya 4-Button Scene Switch TS004F
description: Automate your Tuya 4-Button Scene Switch (TS004F) via Zigbee2MQTT.
domain: automation
input:
switch:
description: Tuya 4-Button Scene Switch to use
selector:
entity:
domain: sensor
integration: mqtt
button_one_short_press:
name: Single Press - Button 1
description: Action to run on button 1 (upper-left) single press
default: []
selector:
action: null
button_one_hold:
name: Hold - Button 1
default: []
selector:
action: null
button_one_double_press:
name: Double Press - Button 1
default: []
selector:
action: null
button_two_hold:
name: Hold - Button 2
description: Action to run on button 2 (upper-right) single press
default: []
selector:
action: null
button_two_double_press:
name: Double Press - Button 2
default: []
selector:
action: null
button_two_short_press:
name: Single Press - Button 2
description: Action to run on button 2 (lower-right) single press
default: []
selector:
action: null
button_three_short_press:
name: Single Press - Button 3
description: Action to run on button 3 (lower-left) single press
default: []
selector:
action: null
button_three_hold:
name: Hold - Button 3
description: Action to run on button 3 (lower-left) long press
default: []
selector:
action: null
button_three_double_press:
name: Double Press - Button 3
default: []
selector:
action: null
button_four_short_press:
name: Single Press - Button 4
description: Action to run on button 4 (lower-right) single press
default: []
selector:
action: null
button_four_hold:
name: Long Press - Button 4
description: Action to run on button 4 (lower-right) long press
default: []
selector:
action: null
button_four_double_press:
name: Double Press - Button 4
default: []
selector:
action: null
source_url: https://gist.github.com/edememinov/1ae89374ece50d2aa4beee4bf8f3fd76
mode: single
max_exceeded: silent
variables:
command: '{{ trigger.payload }}'
topic: '{{ trigger.topic }}'
switch_name: !input 'switch'
deviceName: '{{ state_attr(switch_name, ''friendly_name'') }}'
- platform: mqtt
topic: zigbee2mqtt/+/action
- choose:
- conditions:
- '{{ topic.split(''/'')[1].replace(''/'', '''') == deviceName.split('' '')[0]
sequence:
- choose:
- conditions:
- '{{ command == ''1_single'' }}'
sequence: !input 'button_one_short_press'
- conditions:
- '{{ command == ''2_single'' }}'
sequence: !input 'button_two_short_press'
- conditions:
- '{{ command == ''3_single'' }}'
sequence: !input 'button_three_short_press'
- conditions:
- '{{ command == ''4_single'' }}'
sequence: !input 'button_four_short_press'
- conditions:
- '{{ command == ''1_double'' }}'
sequence: !input 'button_one_double_press'
- conditions:
- '{{ command == ''2_double'' }}'
sequence: !input 'button_two_double_press'
- conditions:
- '{{ command == ''3_double'' }}'
sequence: !input 'button_three_double_press'
- conditions:
- '{{ command == ''4_double'' }}'
sequence: !input 'button_four_double_press'
- conditions:
- '{{ command == ''1_hold'' }}'
sequence: !input 'button_one_hold'
- conditions:
- '{{ command == ''2_hold'' }}'
sequence: !input 'button_two_hold'
- conditions:
- '{{ command == ''3_hold'' }}'
sequence: !input 'button_three_hold'
- conditions:
- '{{ command == ''4_hold'' }}'
sequence: !input 'button_four_hold'
Known limitation:
Friendly name has to be set for the button in Z2M
This only works with 1 switch for now.
Support for multiple switches coming as soon as I figure out how I can use switch friendly name as a variable in the mqtt topic
Update:
Now works with multiple devies.
Update 2:
Updated for Z2M v 1.22.1-1.
Added double press and hold for all buttons
The following button commands work:
- Button 1 short press
- Button 1 double press
- Button 1 hold
- Button 2 short press
- Button 2 double press
- Button 2 hold
- Button 3 short press
- Button 3 double press
- Button 3 hold
- Button 4 short press
- Button 4 double press
- Button 4 hold
