Description is: Temperature & humidity sensor with display but it doesn’t have a display …
Temperature updates around every 30 minutes (possibly quicker if it is changing rapidly). Humidity updates around every 30 minutes.
In its current configuration it is little more than a pathetic ornament! Disappointing for a Danfoss branded product.
Wish Ruuvi made a Zigbee version of their RuuviTag or RuuviTag Pro. They report every few seconds, with air pressure and motion, too. However, without meshing like Zigbee the range can be less.
I just wanted to share that I was able to get the TZ3000_qaaysllp TS0201 integration working through Smarththings with the help of this dev. He was able to connect the dots between the functioning ZHA device handler and his smartthings edge drivers. I now have this reporting to smartthings and HA quickly and more accurately than the device itself (bogus battery readings on LCD - always low).
I will likely switch to SkyConnect soon, so this may be moot for me if I can remove the samsung hub, but hopefully it helps others!
[Disregard the discrepancy in the HA screenshot’s data. Taken several minutes apart.]
