Tuya TYWE1S flash help
Hello everyone,
I recently purchased a Zemismart Smart Curtain kit (exactly this one --> https://it.aliexpress.com/item/4001106838117.html?spm=a2g0o.detail.0.0.321e7401HWwrff&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=6a1cb4d6-d6c1-4e48-beac-1a197427f328&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:6a1cb4d6-d6c1-4e48-beac-1a197427f328,tpp_buckets:668%230%23131923%2383_668%23888%233325%2318_668%232846%238116%232002_668%232717%237558%23148_668%231000022185%231000066059%230_668%233468%2315609%23274) which comes with an USB/Wi-Fi dongle.
The USB/Wif-Fi dongle is equipped with a TY-TYWE1S chip:
Which I would like to flash with Tasmota firmware using Tasmotizer and the USB to Serial converter in the picture below:
I noticed that the same USB/Wi-Fi dongle has been flashed as per this guide here --> https://tasmota.github.io/docs/TuyaMCU-Devices/
But I am stuck with the flashing process because I cannot understand what has been soldered to what and I need some help on this.
Specifically I am not able to understand this picture --> https://user-images.githubusercontent.com/43923557/64847157-7899df80-d662-11e9-8133-2c6201658ec2.jpg
He is using an USB to Serial converter which has more connections than mine (for example, D+ and D- are not present in mine, and he is using those to connect U1RX and U1TX).
I successfully flashed TYWE3S chip and Shelly One with the Tasmotizer + USB to Serial converter combo in the past and I am applying the same principles with this TYWE1S chip but without success.
This is the GPIO layout of the TWYE1S chip:
And I am connecting it this way:
Tuya Chip —> USB to Serial converter
U1TX to RXD
U1RX to TXD
GND to GND
IO0 to GND
3V3 to VCC (the USB to Serial converter is set to 3v, not 5v)
By doing this way, Tasmotizer is failing to acquire a connection with the device and I am unable to erase the Tuya firmware on it and replace it with Tasmota.
Can anyone help me out on this, please?
Thank you
Try U0RX, U0TX
Hi yogi1, thank you for the suggestion and the TYWE1S GPIO scheme.
So, I soldered as per these pictures:
And shorted GPIO and GND this way:
(yes, my soldering skills suck)
Then, I connected everything to my USB to Serial converter like this:
3v3 to VCC
GND and IO0 to GND
U0RX to TXD
U0TX to RXD
Unfortunately I am unable to obtain an IP address from Tasmotizer so the flash procedure cannot start:
I am really stuck. What am I doing wrong?
No need Device IP on Tasmotiser. See the link read it carefully from top and go to " Tasmotizer!"
https://tasmota.github.io/docs/Getting-Started/
To put the ESP8266 into Programming Mode:
Disconnect serial-to-USB adapter and power
Bridge GPIO0 and GND (by pressing the on-board button or connection with a wire)
Connect the serial-to-USB adapter to your computer
After a few seconds disconnect GPIO0 from GND.
Then go " Tasmotizer!" in link.
Once flashed. Go to
Initial Configuration
Using Web UI
Configure Wi-Fi
Once you configure wifi on Tasmota webpage. Your AP mode( http://192.168.4.1) no more live. Then you can find Your IP on your router or on “Fing” App.
Hello everyone,
I just wanted to post an update on this: turns out I am an idiot.
I spent the last 4 days trying to figure out why I wasn’t able to flash this damn thing.
Yesterday, I grabbed a couple of old Shelly 1 and Sonoff S20 that I had laying around and tried to flash those. I wasn’t able. Baffling, since I flashed those exact items in the past with the same USB to Serial converter, same cables, same software running on the same PC.
I troubleshooted a bit with Tasmotizer and discovered I was failing because it couldn’t communicate on COM1 (I was getting an error message saying that I didn’t have permission on that ///COM1 port).
Turn out that my PC lacked the proper PCI Serial Port drivers (I updated it to Windows 10 20H2). I never needed to download anything in the past and I flashed everything correctly. I grabbed the correct PCI Serial port driver from the web, installed those and restarted Tasmotizer. Now I was able to flash the Zemismart Curtain USB dongle on COM3 port and I finally managed to configure the curtains following this helpful post here --> Curtain Automation
I am now able to control it in HA as if it was a dimmable light and it works just fine!
Hi, I tried to follow this guide but it didnt work for me, so I am writing this for anyone else that may buy a Zemismart smart wifi curtain after this post.
The chip in the motor is a TYWE1S but it also had headers on it. So I plugged it into a breadboard and powered it that way and also grounded it. That way I only had to stick TX and RX wires to the chip. Just to clarify, you can use those headers to power the board and by extension, it also powers the chip.
I then powered up the chip by connecting my serial programmer to my PC. I then used one of the ground cables to connect to IOO and then used the other ground gable to connect to reset. All you need to do is just touch the points and hold them. I then let go of reset and clicked tasmotize but kept the wire touching IOO. After I saw the transfer start, I took the cable away from IOO.
Here are some pictures to help. If you look at the headers on the right hand side of the board, they will have letters next to them. I put the power cable from the programmer in the header labelled V and the ground cable from the programmer in the header labelled
Hope this helps someone.
Thx @hadeshorn for sharing – worked like a charm on my BCM500DS-TYW
Have you figured out Tasmota Config for this device?
I have it set up for ESPHome, let me know if you need help with that.
@hadeshorn i am interrested in your help freeing my heater.
I want to flash esphome on my tywes1.
  • i conected as you only rx and tx,
  • bridge temporarly io0 to gnd
  • switch on my heater and open web.esphome.io from my chromium browser
  • select my ttyUSB4 device
  • release the bridge
  • then flash
but it always tell me “Failed to initialize. Try resetting your device or holding the BOOT button while selecting your serial port until it starts preparing the installation.”
could you help me ?
damne
i just found that my ground had to be connected between my tywes1 and my usb/serial
:shushing_face:
ok now i flashed esphome
access and flash it with homeassistant thrue wifi.
but the board does nothing.
i observe that only the first 5 pins vcc, u1tx, u1rx, 3v3 and gnd are connected to my heater board.
this helped me to print debug from urx1 and utx1
to read datas and make a sensor with it i opened a new post How to extract value from uart text sensor
Hi guys. I have this broken TYWE1s stick. is offline and no longer emits blue light.
Is there a possibility to replace it with an esp?
I just got this same Smart curtain with the TY-TYWE1S USB dongle. However, the USB dongle seems to be burned. The LED does not power on, and even in Windows or Linux, the USB is not recognized by either OS.
I don’t have the RF controller either.
Is there any way to use an ESP32 or 8266 instead?
I’ve looked far and wide and it appears there are no pin compatible drop in replacements for the TYWE1S. You can buy a replacement though if that works for you. 1PCS TYWE1S Low power embedded Wi Fi module 100% brand new and authentic, ready to ship in stock - AliExpress 502
It is a ESP8266 so can easily run ESPHome or Tasmota on it.
What type of gum/glue did you use to hold the two wires in place?
I found an easy way to flash these without any soldering involved. Simply 3D print the Tuya TYWE1S Soldering Jig
I used P75-B1 E15 15.85mm Test Probes: https://www.aliexpress.com/item/1005002667659397.html
Then attached test hook clip to dupont cables to them which then plugged into my serial flasher: https://www.aliexpress.com/item/1005007259639128.html
For simplicity I used a dupont divider to connect both GND and IO0 to ground.
2.54 DuPont Line 1P One Divided into Two Line Split Line - AliExpress
Attach to U0TX, U0RX, IO0,3.3V and any one of the GND connections. Then fire up Tasmotizer or ESPHome-Flasher and away you go. Once it’s flashed remove IO0 and reboot the device by removing 3.3V and re-applying it.
It’s interesting that with Tasmotizer or ESPHome-Flasher it could put it into flashing mode automatically. But with web.esphome.io after you click Install you have to unplug IO0 from the serial flasher, and then it works. Likely the browser has less deep access to the hardware COM ports. I personally used Tasmotizer so that I could save the tuya .bin file first, in case I needed to re-flash it to diagnose how the device worked.
If like mine yours is attached to a carrier board you could start out by flashing it with the esphome-kickstart esp8266 firmware: GitHub - libretiny-eu/esphome-kickstart: Precompiled LibreTiny-ESPHome firmware allowing identification of device pins and OTA upgrading
Then go through each pin and pull them high and low and see what happens. When I did OUTPUT_HIGH on pin 5 the status led turned on.
I was able to flash this chip without fully removing it from my Portable AC. I of course unplugged my AC from power first.
