Isn’t this because of apparent vs reactive power maybe? Tuya app maybe exposes the lowe one. This can be checked running an AC motor (fan, blower, etc…) and checking the values
I have same issue and don’t know how to set it up in local tuya integration can someone help ?
I have below model :
https://es.aliexpress.com/item/1005004845740618.html?spm=a2g0o.order_list.order_list_main.5.489d194dRWPNQx&gatewayAdapt=glo2esp
Hi there…
I have another problem…
I can link my dual WiFi meter to home assistant. I can create my entities.
I have infos about prod or power injection, but I have kw instead of w.
I can produce, 4 kw with my panels but when I use dual WiFi meter, it’s said I produce 40 kw.
Any tips to have the correct value unity ?
(Home assistant core on raspberry pi 4), last build.
Ty
It seems good but I am stuck when he asks to run command line.
How do you do that ?
thanks
Use tuya local.
Continuing the discussion from Tuya WiFi Digital Meter:
I can’t connect my Wifi Meter to the HA. In the SmartLife app it works perfectly, just like on the IOT Platform.
you have to configure it through Tuya Local, get the device ID key, local_key from the website us.iot.tuya.com and your local IP from your home network
I tried using Local Tuya, I got the data from IOT(http://us.iot.tuya.com/), but every time I try to log in to HA it says incorrect username.
Voce utiliza o mesmo sensor ? https://pt.aliexpress.com/i/1005005936213394.html
This has to be the case now
make-all/tuya-local: Suporte local para dispositivos Tuya no Home Assistant (github.com)
Yes, I use the same model but white
Isn’t it possible to flash the Tuya power Clamp with ESPHome or Tasmota ?
Hello I have the same issue… I tried to do a lot of things without success… ![]()
Someone could put here a step by sep manual (for rookies)
Please help me I’m out of ideas… And I tried to follow all what you said (surely making something wrong) and it’s not working…
From Tuya mobile app all is working fine… but with HA no
Thanks in avdance!!!
First, you have to go to the Home Assistant. Then, click on Settings, Devices & Services, Add Integration, and add TUYA LOCAL.
