Tuya Wireless switch with 4 buttons Z2M + 2025.1.0
blueprint:
  name: Zigbee2MQTT - Tuya 4-Button Scene Switch Fixed (2025.1.0)
  description: Automate your Tuya 4-Button Scene Switch
  domain: automation
  input:
    tuya_device:
      name: Tuya 4-Button Scene Switch
      description: Tuya 4-Button Scene Switch to use
      selector:
        device:
          integration: mqtt
          manufacturer: Tuya
          model: Wireless switch with 4 buttons
    button_one_short_press:
      name: Single Press - Button 1
      description: Action to run on button 1 (upper-left) single press
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Double Press - Button 1
      description: Action to run on button 1 (upper-left) double press
      default: []
      selector:
        action: {}
    button_one_long_press:
      name: Long Press - Button 1
      description: Action to run on button 1 (upper-left) long press
      default: []
      selector:
        action: {}
    button_two_short_press:
      name: Single Press - Button 2
      description: Action to run on button 2 (upper-right) single press
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Double Press - Button 2
      description: Action to run on button 2 (upper-right) double press
      default: []
      selector:
        action: {}
    button_two_long_press:
      name: Long Press - Button 2
      description: Action to run on button 2 (upper-right) long press
      default: []
      selector:
        action: {}
    button_three_short_press:
      name: Single Press - Button 3
      description: Action to run on button 3 (lower-right) single press
      default: []
      selector:
        action: {}
    button_three_double_press:
      name: Double Press - Button 3
      description: Action to run on button 3 (lower-right) double press
      default: []
      selector:
        action: {}
    button_three_long_press:
      name: Long Press - Button 3
      description: Action to run on button 3 (lower-right) long press
      default: []
      selector:
        action: {}
    button_four_short_press:
      name: Single Press - Button 4
      description: Action to run on button 4 (lower-left) single press
      default: []
      selector:
        action: {}
    button_four_double_press:
      name: Double Press - Button 4
      description: Action to run on button 4 (lower-left) double press
      default: []
      selector:
        action: {}
    button_four_long_press:
      name: Long Press - Button 4
      description: Action to run on button 4 (lower-left) long press
      default: []
      selector:
        action: {}
mode: parallel
max_exceeded: silent
  - domain: mqtt
    device_id: !input tuya_device
    type: action
    subtype: 1_single
    trigger: device
  - domain: mqtt
    type: action
    subtype: 2_single
    trigger: device
  - domain: mqtt
    type: action
    subtype: 3_single
    trigger: device
  - domain: mqtt
    type: action
    subtype: 4_single
    trigger: device
  - domain: mqtt
    type: action
    subtype: 1_double
    trigger: device
  - domain: mqtt
    type: action
    subtype: 2_double
    trigger: device
  - domain: mqtt
    type: action
    subtype: 3_double
    trigger: device
  - domain: mqtt
    type: action
    subtype: 4_double
    trigger: device
  - domain: mqtt
    type: action
    subtype: 1_hold
    trigger: device
  - domain: mqtt
    type: action
    subtype: 2_hold
    trigger: device
  - domain: mqtt
    type: action
    subtype: 3_hold
    trigger: device
  - domain: mqtt
    type: action
    subtype: 4_hold
    trigger: device
- variables:
    command: "{{ trigger.payload }}"
- choose:
  - conditions:
    - "{{ command == '1_single' }}"
    sequence: !input "button_one_short_press"
  - conditions:
    - "{{ command == '2_single' }}"
    sequence: !input "button_two_short_press"
  - conditions:
    - "{{ command == '3_single' }}"
    sequence: !input "button_three_short_press"
  - conditions:
    - "{{ command == '4_single' }}"
    sequence: !input "button_four_short_press"
  - conditions:
    - "{{ command == '1_double' }}"
    sequence: !input "button_one_double_press"
  - conditions:
    - "{{ command == '2_double' }}"
    sequence: !input "button_two_double_press"
  - conditions:
    - "{{ command == '3_double' }}"
    sequence: !input "button_three_double_press"
  - conditions:
    - "{{ command == '4_double' }}"
    sequence: !input "button_four_double_press"
  - conditions:
    - "{{ command == '1_hold' }}"
    sequence: !input "button_one_long_press"
  - conditions:
    - "{{ command == '2_hold' }}"
    sequence: !input "button_two_long_press"
  - conditions:
    - "{{ command == '3_hold' }}"
    sequence: !input "button_three_long_press"
  - conditions:
    - "{{ command == '4_hold' }}"
    sequence: !input "button_four_long_press"
