**Device normal info**
- Brand: EPT Tech
- Model: Smart TLC2206
**Device i…nfo (please complete the following information, which can be found in [log](https://github.com/tuya/tuya-home-assistant/wiki/How-to-get-the-log)):**
like this:
"active_time": 1699101903,
"biz_type": 0,
"category": "ywcgq",
"create_time": 1698697618,
"icon": "smart/icon/bay1610529967139OoVI/f4194654ecceabe31d6174fa1c51ff1c.png",
"id": "bf7d88e7cb634381730xsl",
"ip": "***",
"lat": "***",
"local_key": "***",
"lon": "***",
"model": "EPT_Ultrasonic level sensor",
"name": "Serbatoio acqua San Lorenzo",
"online": true,
"owner_id": "71576573",
"product_id": "wtzwyhkev3b4ubns",
"product_name": "Tank A Level",
"status": [
"code": "liquid_state",
"value": "upper_alarm"
"code": "liquid_depth",
"value": 69
"code": "max_set",
"value": 90
"code": "mini_set",
"value": 10
"code": "installation_height",
"value": 800
"code": "liquid_depth_max",
"value": 120
"code": "liquid_level_percent",
"value": 100
"sub": false,
"time_zone": "+01:00",
"uid": "***",
"update_time": 1699585130,
"uuid": "1437d065c7ef82dc"
**Device specifications (please complete the following information, which can be found in [log](https://github.com/tuya/tuya-home-assistant/wiki/How-to-get-the-log)):**
Same device's id, like this:
2023-11-12 18:15:05.494 DEBUG (SyncWorker_23) [tuya_iot] Request: method = GET, url = https://openapi.tuyaeu.com/v1.0/devices/bf7d88e7cb634381730xsl/specifications, params = None, body = None, t = 1699809305494
2023-11-12 18:15:05.583 DEBUG (SyncWorker_23) [tuya_iot] Response: {
"result": {
"functions": [
"code": "max_set",
"type": "Integer",
"values": "{\"unit\":\"%\",\"min\":0,\"max\":100,\"scale\":0,\"step\":1}"
"code": "mini_set",
"type": "Integer",
"type": "Integer",
"values": "{\"unit\":\"m\",\"min\":200,\"max\":2500,\"scale\":3,\"step\":1}"
"type": "Integer",
"values": "{\"unit\":\"m\",\"min\":100,\"max\":2400,\"scale\":3,\"step\":1}"
"status": [
"type": "Enum",
"values": "{\"range\":[\"normal\",\"lower_alarm\",\"upper_alarm\"]}"
"type": "Integer",
"values": "{\"unit\":\"m\",\"min\":0,\"max\":10000,\"scale\":2,\"step\":1}"
"code": "max_set",
"type": "Integer",
"code": "mini_set",
"type": "Integer",
"type": "Integer",
"type": "Integer",
"type": "Integer",
"success": true,
"t": 1699809311062,
"tid": "0933b8fa817f11eeab249a6504bbc951"
