Tuya ZigBee "Smart Knob"
One trigger for each button. There can’t possibly be less.
You could either make one automation for all the remotes or one per remote and use trigger id to separate the actions.
Events are just something you need to listen for and copy paste to the automation. There is no logic to the values usually.
But doesn’t ZHA expose the remote as a device?
One trigger for each button of each remote… What means for three remotes (one for each bedroom) with possibly 10 actions each… That’s 30 automations polluting the panel and 30 repeated settings I have to make :skull_and_crossbones: I understand why, but I hope this gets a big improvement in future releases :pray:
EDIT: it seems this has been requested more than three years ago. I made a more specialized request of a controller config screen.
As far as I can understand, the events from ZHA are turned into automation triggers, but they’re confusing (I guess because the triggers use standard names which don’t exactly fit the knob actions), to say the least. Then I went down the rabbit role to investigate the actual events and came up with that GH report to see if this can be improved.
And yes, there’s a Zigbee device, but it only shows the battery level and an “identify button” which I can press in the UI but have no clue what that’s for :sweat_smile: But that’s the device the triggers are attached to.
No.
It can be one automation as I said before.
OH. RIGHT. Sorry! I didn’t understand what you meant so I guess my brain ignored it - since it seems to not be a standard option in the UI.
Could you give an example on how to create a single automation for many triggers and then split actions by the trigger?
One way to do this is to give each trigger a trigger id. Then use the Choose action to run actions based on which trigger occurred:
description: ""
mode: single
  - platform: state
    entity_id:
      - binary_sensor.bathroom_motion_sensor_ias_zone
    id: Motion in bathroom
    to: "on"
  - platform: state
    entity_id:
      - binary_sensor.bedroom_2_motion_sensor_ias_zone
    id: "Motion in bedroom "
    to: "on"
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: light.turn_on
            data: {}
              entity_id: light.bathroom_ceiling_light_2_level_on_off
      - conditions:
        sequence:
            data: {}
              entity_id: light.bedroom_2_ceiling_light_level_on_off
WOW. No clue that was possible. Don’t recall seeing that in docs, but found it here.
That sort of changed my life - while it’s still a bit tiring to configure it all by hand, it will definitely be cleaner now! Will try to learn on blueprints too.
Thanks for the description and example! And thanks to @Hellis81 too, for the sort of early pointer which I missed :slight_smile:
If you learn more advanced yaml then you could use variables or using a device mapper to convert to what target device you want to control.
As an example:
{% set target = {"f594d0a16628c130b023f476a35c0091": "livingroom", "other device ID": "bedroom"} %}
could translate the trigger device_id to what room you want to control.
And from that you then use:
service: button.press
data: {}
  entity_id: "button.{{ target[trigger.event.data.device_id }}]_volume_up"
Or whatever the service call is to change volume.
That means all your remotes can work under one automation if you have a strict naming convention so that a template like above works.
Hi, I know this treat is for ZHA, but maybe someone knows how I get this device supported in Z2M. What I tried so far: How to get my Zigbee2MQTT device working (TS004F)
Hey guys,
Has anyone made a blueprint where I can specify events? I want to use this as a media control device.
I made a custom quirk for this device specifically TZ3000_abrsvsou - TS004F
Supports : Mode Change from Hue / Temp Control and Normal Mode,
Single, Double and Toggle, Left Rotate, Right Rotate, Press and Rotate - Left Right. Detect Tripple Presses for Mode Change. Hope this helps someone :slight_smile:
"""Tuya TS004F devices."""
from __future__ import annotations
from zhaquirks.tuya.mcu import EnchantedDevice #old versions
#from zhaquirks.tuya import EnchantedDevice #2024.2 onward
from zigpy.profiles import zha
from zigpy.zcl.clusters.general import (
    Basic,
    Groups,
    Identify,
    LevelControl,
    OnOff,
    Ota,
    PowerConfiguration,
    Scenes,
    Time,
from zigpy.zcl.clusters.lighting import Color
from zigpy.zcl.clusters.lightlink import LightLink
from zhaquirks.const import (
    ALT_SHORT_PRESS,
    BUTTON,
    BUTTON_1,
    BUTTON_2,
    BUTTON_3,
    BUTTON_4,
    CLUSTER_ID,
    COMMAND,
    COMMAND_MOVE,
    COMMAND_MOVE_SATURATION,
    COMMAND_OFF,
    COMMAND_ON,
    COMMAND_STEP,
    COMMAND_STOP,
    COMMAND_STOP_MOVE_STEP,
    COMMAND_TOGGLE,
    DEVICE_TYPE,
    DIM_DOWN,
    DIM_UP,
    DOUBLE_PRESS,
    ENDPOINT_ID,
    ENDPOINTS,
    INPUT_CLUSTERS,
    LEFT,
    LONG_PRESS,
    LONG_RELEASE,
    MODEL,
    MODELS_INFO,
    OUTPUT_CLUSTERS,
    PARAMS,
    PROFILE_ID,
    RIGHT,
    ROTATED,
    ROTATED_FAST,
    ROTATED_SLOW,
    SHORT_PRESS,
    TURN_OFF,
    TURN_ON,
    ARGS,
from zhaquirks.tuya import (
    TuyaNoBindPowerConfigurationCluster,
    TuyaSmartRemoteOnOffCluster,
    TuyaZBExternalSwitchTypeCluster,
#Some of the TZ3000_abrsvsou TS004F Customizations
ROTATED_PRESSED = "Press Rotate Knob HUE Mode Only"
COMMAND_STEP_COLOR_TEMP = "step_color_temp"
PRESSED = "pressed"
TOGGLE = "toggle"
ATTRIBUTE_UPDATED = "attribute_updated"
TRIPPLE_PRESSED = "Tripple Press"
TRIPPLE_PRESSED_NORMAL_MODE = "Tripple press to Normal Mode"
TRIPPLE_PRESSED_HUE_MODE = "Tripple press to HUE Mode"
ROTATED_HUE = "Rotate in HUE Mode"
ROTATED_NORMAL = "Rotate in Normal Mode"
DOUBLE_PRESS = "Double Click in Normal Mode"
LONG_PRESS = "Long Press in Normal Mode"
LONG_PRESS_HUE = "Long Press in HUE Mode"
BUTTON_1_HUE = "Button 1 in Hue Mode"
BUTTON_1_NORMAL = "Button 1 in Normal Mode"
class TuyaSmartRemote004FROK(EnchantedDevice):
    """Tuya Smart (rotating) Knob device."""
    signature = {
        # "node_descriptor": "NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0, *allocate_address=True, *complex_descriptor_available=False, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False, *is_valid=True, *logical_type=<LogicalType.EndDevice: 2>, *user_descriptor_available=False)",
        # SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=260, device_version=1, input_clusters=[0, 1, 3, 4, 6, 4096], output_clusters=[25, 10, 3, 4, 5, 6, 8, 4096])
        MODELS_INFO: [
            ("_TZ3000_4fjiwweb", "TS004F"),
            ("_TZ3000_uri7ongn", "TS004F"),
            ("_TZ3000_ixla93vd", "TS004F"),
            ("_TZ3000_qja6nq5z", "TS004F"),
            ("_TZ3000_csflgqj2", "TS004F"),
            ("_TZ3000_abrsvsou", "TS004F"),
        ENDPOINTS: {
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.DIMMER_SWITCH,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    PowerConfiguration.cluster_id,
                    Identify.cluster_id,
                    Groups.cluster_id,
                    OnOff.cluster_id,
                    LightLink.cluster_id,
                OUTPUT_CLUSTERS: [
                    Ota.cluster_id,
                    Time.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    OnOff.cluster_id,
                    LevelControl.cluster_id,
    replacement = {
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.NON_COLOR_CONTROLLER,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,  # Is needed for adding group then binding is not working.
                OUTPUT_CLUSTERS: [
                    Ota.cluster_id,
                    Time.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    Color.cluster_id,
    device_automation_triggers = {
        #HUE MODE STUFF
        (LONG_PRESS_HUE, BUTTON): {
            COMMAND: COMMAND_MOVE_SATURATION,
            ENDPOINT_ID: 1,
            CLUSTER_ID: 768,
            PARAMS: {"move_mode": 1},
        (ROTATED_HUE, RIGHT): {
            COMMAND: COMMAND_STEP,
            ENDPOINT_ID: 1,
            CLUSTER_ID: 8,
            PARAMS: {"step_mode": 0},
        (ROTATED_HUE, LEFT): {
            ENDPOINT_ID: 1,
            CLUSTER_ID: 8,
            PARAMS: {"step_mode": 1},
        (ROTATED_PRESSED, RIGHT): {
            COMMAND: COMMAND_STEP_COLOR_TEMP,
            ENDPOINT_ID: 1,
            CLUSTER_ID: 768,
            PARAMS: {"step_mode": 1, "color_temp_min_mireds": 153},
        (ROTATED_PRESSED, LEFT): {
            ENDPOINT_ID: 1,
            CLUSTER_ID: 768,
            PARAMS: {"step_mode": 3, "color_temp_min_mireds": 153},
        (TOGGLE, BUTTON_1_HUE): {
            COMMAND: TOGGLE,
            ENDPOINT_ID: 1,
            CLUSTER_ID: 6,
        (TRIPPLE_PRESSED_NORMAL_MODE, BUTTON_1_HUE): {
            COMMAND: ATTRIBUTE_UPDATED,
            ENDPOINT_ID: 1,
            CLUSTER_ID: 6,
            ARGS: {"attribute_name": "switch_mode", "attribute_id": 32772, "value": 1},
        (TRIPPLE_PRESSED_HUE_MODE, BUTTON_1): {
            ENDPOINT_ID: 1,
            CLUSTER_ID: 6,
            ARGS: {"attribute_name": "switch_mode", "attribute_id": 32772, "value": 0},
        (SHORT_PRESS, BUTTON_1_NORMAL): {ENDPOINT_ID: 1, COMMAND: SHORT_PRESS},
        (LONG_PRESS, BUTTON_1_NORMAL): {ENDPOINT_ID: 1, COMMAND: LONG_PRESS},
        (DOUBLE_PRESS, BUTTON_1_NORMAL): {ENDPOINT_ID: 1, COMMAND: DOUBLE_PRESS},
        (ROTATED_NORMAL, RIGHT): {
            COMMAND: RIGHT,
            ENDPOINT_ID: 1,
            CLUSTER_ID: 6,
        (ROTATED_NORMAL, LEFT): {
            COMMAND: LEFT,
            ENDPOINT_ID: 1,
            CLUSTER_ID: 6,
it is now included? i did not need to install this quirk and found the device in zha?!
but i need a blueprint for this device?!
Hello @subrodey thank you so much for your work. Would you be able to transform this into a Blueprint that we could add easily to HA? Similar to another button I’m using: Blueprint and Github page
@biva I went ahead and translated that blueprint to English and changed the manufacturer to work with abrsvsou using Claude Sonnet 3.7
Works on my end, although the device itself seems to be quite bad (events it sends are not constant up or down given clockwise / counterclockwise).
I guess not unexpected given $2 on AliExpress
https://gist.githubusercontent.com/kkilchrist/691dd3979882fce625ee2ac9d7cd392f/raw/570d678027dd2bad96a143b1fc8a3e37681ce861/tuya-TS004F-TZ3000_abrsvsou-knob.yaml
I bought a similar one. I didn’t install a quirk for it, if was already recognized.
At first sight, it worked perfectly. I have a tuya zigbee dimmer and my ZHA put both on the same Default Zigbee group and it controlled the light automatically, and the light change was preatty fast.
But since I need to control another light with it, I tried to create a zigbee group to put them, but seems ZHA has some bug ot not implemented something, because I could not add these knob on them.
So, I created an automation. It also works, but the zha events must be treaten separately and the dimmer Is slow, if you turn it fast, it will not recognize the amount you turned.
Also, at least mine, it has two modes.
You can change them with triple press. The frist mode is something called App mode, where the hardware send some commands that the App will recognize (I don’t know wich App), I think the press button sends a “toggle” command.
The second mode, called something like “remote mode” send more reliable commands to ZHA, like single_press, double_press, left and right (for turning the knob). I used this for the automation.
The commands also sends the amount turned, but I don´t know how to treat them.
I do needed the ZHA groups working, it would be very easier.
Regards
Hey @alexantao, were you able to figure out how to add this device to a group? I’m having the same issue, I keep trying to add it to a group but it’s never done.
I used to have the knob binded to a couple of lights in z2mqtt and was working fine. But since I moved to ZHA it seems impossible.
Hi @sloydev ,
I answered by email, but seems it didn’t arrive.
I got to add it to ZHA group using ZHA Toolkit integration.
This integration permit us to send ZHA commands directly in Developper Tools inside HA.
I still need to give some tries, but I got to add the knob to a separated group.
But in my particular needs, i am using normal automation (until I have time to come back to this issue) because making this seems I loose the double click functionallity. It sends other types of Zigbee events and I could not be able to use them. But I think its possible.
Regards.
Thank you very much for the blueprint. I had bought a SmartKnob and was looking for a way to integrate it, but that turned out to be really difficult. Then I found your blueprint. However, you restricted the manufacturer, which didn’t work for mine, so I had to create the blueprint manually and remove that line. Here are the details of my knob:
"manufacturer": "_TZ3000_gwkzibhs",
"model": "TS004F",
"class": "zhaquirks.tuya.ts004f.TuyaSmartRemote004F"
If I leave out the manufacturer in the blueprint, I can select my knob and everything works — thanks to you.
