NAS ER01B (+/-17€) : I read some critic about whistling noise
For me the most important is the instant power in kW and cumulative energy in kWh by day, week, month
Thank
Do not buy the TS011F
I have 14 of them and they al switch off at random (even if their is no hub/coordinator)
Sometimes they keep working good for days/weeks but you cant use them for devices that must always be powered on like a modem / router / fridge / freezer
Very quickly, almost instantly
I use a conbee stick with it and you can configure the refresh time in seconds with the build-in DDF Editor. I believe the default is 30 seconds but you can set it to 1 sec if you want.
Keep in mind that zigbee has a limited bandwidth and if you have many devices then setting it to 1 second will fail refresh values often.
I have 9 plugs TS011F and they did not turn off once. This was a bug that was patched.
Also I use zigbee2mqtt and you can set their refresh rate to 1s. I set them all without any troubles. Plugs are routers, they do not have any problems to pass data constantly through the network.
I am using z2m and the TS011F does not show its firmware vesion there but it is shown in HA, which is capable to update it. I am using them everywhere, from Synology NAS, dishwasher, washing machine, refrigerator, DLP projector… it never turned off. It is zigbee version and I bought it in two batches from China.
So update them and give it a try. They are great. You can set a lot of configurations in z2m including 1sec refresh and I do not see any troubles here. Solved my problem 5eur instead of 30eur per piece.
With Zigbee2MQTT, are you able to have directly the energy in (k)wh in HA.
I mean, you don’t need to use a " Riemann" to calculate the energy based on power.
It is better to have the cumulative energy coming from the device so in case HA is shutdown or Network is down then the energy will be restored with exact value from the device.
With this : https://zigbee.blakadder.com/Tuya_TS011F.html
With this : https://zigbee.blakadder.com/Neo_NAS-WR01B.html
Can you confirm which device will provide energy and power separately ?
Thank to help me to choice the best device. i have +/- 10 to order.
Curently, I have MEROSS MSS310 (witch are not zigbee) and I don’t get energy (only power, but it is useless. Most important is energy).
Am in the market for a Zigbee smart plug, and would like to ask existing users some questions.
I am using SkyConnect stick in HA, and need to create power-on schedules for my espresso machine. Can schedule configuration be done the Tuya app through the SkyConnect stick? Will the Tuya iOS app work in the absence of a Tuya Zigbee gateway?
Are the power schedules on-device, and if they work even without Internet access? The smart plug will be powered on 24/7.
Is there any way to amend timer schedules via HA? My ultimate aim is to create an automation, such that the power schedules are adjusted against my calendar.
I’m in the market for some more smart plugs, and since most of the ones that are being offered (that are also not that expensive), are some kind of Tuya derivative (like the Blitzwolf ones).
However, since there are some warnings about them turning off/on at random, I am doubing a bit whether or not to drop some cash into them.
I have 9 of these plugs operational as well and I switched from z2m to zha recently. What I didn’t notice until now is that the plugs are repeatedly reporting energy. It’s driving my network a bit crazy. Is there a zigbee control command to set the measurement reporting status? I did find one in the documentation of z2m, but as I’m running zha now, I can’t seem to find this command anywhere in ZHA.
So is the moral here that HA can’t pick up energy monitoring signals from zigbee devices without a bridge translating the sensor readings to mqtt messages?
Just bought 6 “Bseed” TS011F_plug_1 _TZ3000_o1jzcxou – Updated firmware to latest 192 I think it was - none of them show any values for power/voltage/etc “metering”. Using z2m. Any ideas?
Doesn’t report any metering even if I bought the power metering model. I’m using ZHA and did the firmware update (0x000000c0) available since 2024.3 but it’s not better
It seems the firmware update makes new clusters available when appairing again, but power sensors still do not work. Child lock is working. I tried to add it to a new HA instance with Z2M, same result…
I sent an email to BSEED to try to get technical support, wait and see their answer
