Great there is an Unify addon!
While installing I encouter the following error. Any idea why?
Log Details (ERROR)
Tue Dec 05 2017 10:28:00 GMT+0100 (West-Europa (standaardtijd))
Error setting up platform unifi
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
conn = self._new_conn()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7402f570>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='localhost', port=8443): Max retries exceeded with url: /api/login (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7402f570>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 149, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/unifi.py", line 60, in get_scanner
site_id=site_id, ssl_verify=verify_ssl)
File "/usr/lib/python3.6/site-packages/pyunifi/controller.py", line 89, in __init__
self._login(version)
File "/usr/lib/python3.6/site-packages/pyunifi/controller.py", line 148, in _login
r = self.session.post(login_url, params)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 555, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='localhost', port=8443): Max retries exceeded with url: /api/login (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7402f570>: Failed to establish a new connection: [Errno 111] Connection refused',))
Thanks!
