Hi kolossboss, the jsons are not configurable in this add-on.
If you have root access to your hassio maybe you can find the Docker folder?
thx for reply. I tried to find the Docker folder. Its the official Resin Rapsberry hassio image. I dont know how to do this.
But no big deal. My needed configuration will be integrated into the Controller in Version 5.7.xx.
Great there is an Unify addon!
While installing I encouter the following error. Any idea why?
Log Details (ERROR)
Tue Dec 05 2017 10:28:00 GMT+0100 (West-Europa (standaardtijd))
Error setting up platform unifi
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
conn = self._new_conn()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7402f570>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='localhost', port=8443): Max retries exceeded with url: /api/login (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7402f570>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 149, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/unifi.py", line 60, in get_scanner
site_id=site_id, ssl_verify=verify_ssl)
File "/usr/lib/python3.6/site-packages/pyunifi/controller.py", line 89, in __init__
self._login(version)
File "/usr/lib/python3.6/site-packages/pyunifi/controller.py", line 148, in _login
r = self.session.post(login_url, params)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 555, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='localhost', port=8443): Max retries exceeded with url: /api/login (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7402f570>: Failed to establish a new connection: [Errno 111] Connection refused',))
Thanks!
Hi Sharki,
ever tried to set the option verify_ssl
to False
Best
Marc
Thanks a lot! That solved the problem.
Is it possible to verify the certificate, instead of just disregarding it?
A merry Christmas to anyone reading this
You would have to install/trust the certificate in your OS or install a valid certificate.
I have the Unifi controller working fine on my hass.io install on a raspberry pi. I can login to it from any pc through [my_duckdns.org_name]:8443 and the AP is adopted and available in the controller. I have created a write protected admin user to use for hass.io. I have entered the following into my configuration.yaml:
device_tracker:
- platform: unifi
# host: !secret unifi_host
username: !secret unifi_username
password: !secret unifi_password
I get the following error:
2017-12-29 19:14:15 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform unifi
chunked=chunked)
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/usr/lib/python3.6/site-packages/urllib3/util/ssl_.py", line 329, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.6/ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "/usr/lib/python3.6/ssl.py", line 814, in __init__
self.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 1068, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 689, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:777)
Any ideas?
It worked after adding:
verify_ssl: false
to my config.
How do I upgrade the Unifi controller firmware in hass.io?
I have 5.6.26 (Version: atag_5.6.26_10236) and I can see that version 5.6.29 has been released. The only upgrades I find in the Unifi maintenance tab is for my AP’s.
@tomoqv did you find how to update the firmware?
Settings > Maintenance > Check Firmware Update
does not seem to work for me, so a bit stuck.
No I didn’t. After some issues with my hass.io installation, I decided to put the Unifi controller on an Ubuntu server instead.
Thanks, I might end up doing the same. Shame as it would be nice and tidy on hass.io
Tried this?
I found that rebuilding the controller installs it with the latest version i.e. it is the only way I have found to upgrade the Unifi controller version.
This is great! Anyway we can select the beta version for install? I am currently running 5.9.4.
