home assistant is starting… I got a 180bpm and renamed back to VM Network but the error message remains (on console opening).
What did I break? Googling does not give me a usable answer.
Any help greatly appreciated.
Thanks in advance.
EDIT: It seems there is an issue introduced in hassos 5.11 (I am not sure it is the case but that is the consensus from below).
Also I do not know how to or where to properly get this issue resolved (github?)
EDIT: To be clear. It was not me that has selected “the solution”. Frenck did do that himself. I still have the error and weird problems after posting this. Also following this with great interest.
I’ve had this today too. But for me it’s unclear what I did to trigger it. My error is the same except i have [638] instead of [529].
Is someone able to clarify if the “Address in use” refer to IP address, or something else? Because that’s what I’ve been changing today - changing other devices on my network from DHCP to static by setting them in the devices themselves. I hadn’t got to my HA instance yet.
My HA runs on a Pi4, though isn’t network accessible at the moment…
I removed my Conbee II stick from the VM and at least HA now boots. However deconz does not start. So it looks like a Deconz issue.
I am now making sure I have everything backed up and I will try to add the hardware again to see what happens
I am running Deconz on a separate docker image, so not sure how that would influence my boot process. The supervisor is running and I can get a terminal window, but the webinterface is not available
I have got the same. Updated OS and Deconz ++ to latest. Running supervised Home Assistant on Mac mini 2014 in Proxmox. During the same night the CPU went to 100% and I have a huge challenge in shutting down the VM and restart the whole server. Now everything works, but still have the udevd error message in console at login. I get really frustrated when the system goes to 100% and everything locks. I have not been able to find out what is causing it Not sure how to troubleshoot except looking at the syslog. But from there is is hard to find what is causing the 100% CPU load. Are there any logs in HA I can use looking at CPU load?
