Updated to 2021.2.3 and still no go for ZWave.JS.
Powered down the VM, unplugged USB Aeotech Gen5 stick and bootet up. Still same error message and addon unavailable as expected. Powered down again
Plugged in USB stick in another USB port in the pc and bootet up VM. Works fine (so far, crossing fingres).
Hope this can help others.
So the only USB item for me was a Wyze Sense hub. I removed it, including itās integration components. I started up from HAos 4.16 backup VDI. Upgraded items one at a time and eventually got down to having only HAs 5.11 remaining. backed up and even copied my VDI. Was running stable, though it was a little slow on startups from a reboot. I rebooted 3 times to verify.
Ok, reinstalled Wyze integrations from HACS and restarted. So far so good. Plugged in Wyze Sense Hub/Bridge (the little white usb brick transmitter with blue light). Restarted per GitHub instructions, and itās been 1hr and has not come up. Headed to lunch and hopefully it will resolve.
So Iāve spent 4 days troubleshooting. I appreciate what everyone is saying, but thereās something amiss.
I think so far we can agree on that something concerning USB devices is triggering this. For me it is starting of Deconz with the Conbee II stick.
I also have an TI CC2531 connected to the same instance which is a test for ZHA. That seems to be working fine.
In the logging I indeed saw the dtr/rts error as well.
+1 from meā¦ deCONZ (ConBee II) in Oracle VirtualBox on Windows 10.
What I noticed, but isnāt mentioned yet: When this problem occurs, I hear the Windows USB-disconnection sound in ~2-5 second intervals (but no connection sound).
Update hereā¦So working with the boys over at @digiblur Discord, we determined that the errors were somehow affecting āthe recorderā. Removed the Wyze USB, deleted the home-assistant.log and a home-assistant_v2.log, and HA restarted in less than 3min. Shocked me how fast. So the error we see on the VM is still there. Plugged the Wyze USB bridge back in and it came up, but all my Wyze sensors will not come up. I donāt think those are related, as the Wyze sensor problems are a known PITA. As it stands, I am up to date on my loads and at least workingā¦very fast I might add.
I too am having this issue running on a raspberry pi 3b+. itās taken my system completely offline. multiple restarts and it never comes back up. since I canāt get into the web UI Iām kinda of at a loss on what to do.
Finally fixed my specific issue! The latest version of Deconz desktop app does not communicate with the latest version of HA. Any Deconz version 2.09.01 and under works!
My Setup:
W10
VirtualBox Ubuntu Install
Conbee II Firmware26680700 / Desktop App 2.09.01
