Does anyone have any advise for this? I want to put something inside the plug socket to control this? I’m sure a brand existed before, can’t recall the name. Would one of the SONOFF ones work? Or are these for light switches?
No. Not a smart plug (like this or lightwaverf)
Something that sits inside a dump uk plug socket
Ah ok. Any smart relay that is rated enough for the socket then. Note for a double socket you’ll need enough to switch 26A, not sure they exist as both sockets are connected internally.
This is what I need to control.
Might just be easier to replace the switch socket and use a smart adapter. Just wanted something inside switch that was zigbee. Google has failed me this time
Gotcha, that’s not a socket but a fused switch spur flex outlet. You could use a smart relay behind but make sure its rated for 13A+ Note there will most likely not be room behind there for it, you’ll need to remove the backbox and fit a deeper 47mm one.
There is a smart FSU available but it’s WIFI
In fact Database of Zigbee devices compatible with ZHA, Tasmota, Zigbee2MQTT, deCONZ, ZiGate and ioBroker
That could work. Do you have one? Can anyone confirm this works with HA?
No I haven’t got one. The post above does show an unofficial MQTT python service but has a bit of setting up by looks of it
Just come across this looks ideal for you
