Ulanzi Stream Deck D200 with Home Assistant
Demo video: https://youtu.be/S1V3YHe_Eoo
Deck info: Stream Controller D200 - Best Stream Controller - Ulanzi (~$55 on Aliexpress)
It’s much cheaper than the Stream Deck, and I kinda like it. They have an official plugin for Home Assistant, but it doesn’t work properly, and it’s not very flexible. I also don’t like that I can only use it when the PC is not sleeping. So I decided to “hack” it.
I’m working on a project to make it work without having to connect to a PC and use there app, which means you can connect the deck to a RPi Zero 2W and place it anywhere in the house.
I’ll update the progress in this post.
The project will be open source.
That is amazingly good timing, i’ve literally just received mine yesterday, loaded the HA plugin and was immediately dissapointed by how terrible the UX was, I can barely get it to do a thing.
I’ll be following your efforts really closely.
This project can now interact with HA via Websocket API, and changes the button’s state accordingly (using templating). Now I’m focusing on clearing the bugs.
Awesome, not sure of your background, but I am more than willing to collab on the UX if desired
Thanks. At first you’ll have to edit the config file directly, but later I want to implement a web editor.
Update: at first I want to install this on a standalone pi zero, but now I want to use HA addon & esphome instead (running esp32-s3). This will reduce the cost and make it easier to manage multiple decks in one place (the addon).
This soudns quite interesting - tactile buttons would be nicer than touch screen in some cases. Do you already have the code available somewhere?
Not yet. I need to test it running on the Orange Pi Zero 2W first.
The code will be available here: redphx/strmdck · GitHub
Here is the current state: https://youtu.be/6KuVNlX7fyE
I walked back on the decision to switch from the Pi Zero to the ESP32 because it would take longer.
Pretty cool, really tempted to order one and some tiny SBC to go with it :slight_smile:
Something like a Luckfox Pico or a Milk-V might be an even cheaper option than a Zero clone.
I don’t think it will work with those boards. It needs to have at least 2 USB ports: one for connecting with the Deck, and another for power supply.
That’s why I went with Orange Pi 2W instead of RPi Pi 2W. I like having USB Type C.
Fair enough and once you start messing with a USB hub it becomes kind of pointless…
Update: it works on the Orange Pi 2W as expected. Now it’s time for fixing bugs before releasing the initial version.
Writing documents, my least favorite part.
I wanna spend a little more time to add some new features (1 more week).
If you want to run this project, you need to prepare these parts:
Testing sensors and binary sensors. Only pagination feature left and I think it’s ready for the initial release.
I love the Home Assistant community. This is so cool
:white_check_mark: Local icon
:white_check_mark: Multiple icons + texts in one button
:white_check_mark: Pagination
Happy seeing this to be released soon :heart_eyes:
I need to stop adding more features :smiley:
Right now I’m working on an addon for HA to control the deck and edit the config file remotely.
Aaaaaand ka-ching, ordered one right now :sweat_smile:
