Do I have to use the Ultraloq app and create an account for this lock to work with Home Assistant? Asking because I thought " Works with Home Assistant" meant it can work with Home Assistant without such requirements.
The very requirement of " Register account and add new lock in U-tec App" is anti-Home Assistant ethos.
There was a bit of drama with U-tec. They were non-responsive regarding issues with their locks, and were temporarily removed from the âWorks with HAâ program. Theyâve since made some firmware updates available (even adding it to the Z-Wave JS firmware service) and look to be more engaged, so I presume they were re-added into the program.
I think âworks with home assistantâ does not follow founding principle of local only. If account can be link it counts as working. Not that this is bad, just not what would be expected and may need some more thought in my meaningless opinion.
That said, it is zwave lock so presuming you use zwavejs for zwave you should look there for supported feature set. I would imagine lock, unlock, status and battery may be supported but you never know.
I would agree. However, I think itâs logical to assume âWorks with Z-Wave via Home Assistantâ assumes support for local only usage. Z-Wave is all about local-only and interoperability with any hub, so it is surprising that a special app and account are required.
From the original announcement:
Ultraloq smart locks connect and integrate into Home Assistant using the Z-Wave integration (Z-Wave stick required).
No mention of an account and app requirement, nor so on the integration page.
Step1
Set the Z-Wave network main controller or hub into inclusion mode.
(presume this means, start Z-Wave JS Add Device)
Step2
Press the button 5 on the lock keypad, until you hear beep sound and the indicator light flashes blue.
(No idea what state the lock needs to be in. Tried right after factory reset, after initial admin pin, still never get the âindicator light flashed blueâ state.)
If your Z-Wave hub is Security 2 enabled and requires the Z-Wave QR code or pin code to add the lock automatically, please ďŹnd it on the back of the battery cover of your smart lock.
Step3 (never got here yet )
Follow the instructions of your Z-Wave hub to finish the inclusion process.
Did you try the QR code? Supposedly it supports SmartStart, which means you can scan the QR code to provisionally add it, then either factory reset or simply power-on (in a non-included state), and it would then add itself after a short time.
Well that doesnât answer my question about which controller you have, but I can guess you either have a Nortek HUSBZB-1 or Aeotec Gen5 fw 1.0. Neither of those support SmartStart unless you upgrade the firmware, so youâre stuck with Classic inclusion.
Instruction manual page 16 or so tells how to set it up in "Standalone"mode.
Based on instruction it seems the app is not required but they hide that bit.
You MUST factory reset it to use in Standalone mode. Once it has been connected to app Standalone mode will not work and it must be factory reset to allow Standalone.
Here is a bunch of useful info on the lock and zwave . That page includes specs and manuals on device
Thanks, i can get it to set up a local setup but Home Assistant Z-Wave cannot see the lock. That is my current problem.
If I install the app, setup an account, get the Z-Wave working, remove the account, remove the app, the Z-Wave should remain. Theoretically.
The page you linked does have something good in it, under Networking there is a step action how to start inclusion. It just does not tell how to get to that stage (step 2).
I come to realize that there is no, none, not one smart lock that does not demand an app on a cell phone at least initially, and works with Home Assistant.
If you can return it DO IT NOW. I have some schlages that are very nice. No fingerprint but pin codes is good enough for me and I usually just unlock/ lock from HA.
Iâve had devices in past that Require app setup and I always wonder what will happen if manufacturer stop publishing app. This is not free for IOS. Can I never reset device for fear of losing access. Android it is somewhat less of an issue since you may be able to backup and side-load but IOS this is impossible. If app is required dump it now.
I was able to connect this to my Z-wave hub in standalone mode. To do so, I went to the Z-wave integration, Add Device, then copied the QR code from inside the battery cover and pasted into the Smart Start field. I had already set the lock up in standalone mode, but I had to reset it (by using the included pin to press the button on the bottom side of the interior piece of the lock). Once I did so, it appeared in Home Assistant.
The Kwikset 620 Z-Wave deadbolt works without any issues. KeyMaster picked it up, without issues, and it is now functioning without anything outside of Home Assistant & HACS.
