Unable to connect to home assistant authorization was revoked
yea, guess it must be one of these plugins. Just upgraded core and the android app is working.
I am getting this same error ever since one of the last 2 updates. Doing the app deletion and rebooting HA several times seems to resolve it, however that is quite a bit of effort. Wouldn’t be so bad, however I noticed that even if I accidentally logged out of my android HA companion (to connect to a different instance), it makes me go through that entire process again. Issue is on my android phone, android tablet and ipad. I’ve not seen this issue in the last 3 or so years i’ve had HA running and so I’m hoping there is some sort of cache clearing update in the future that negates this issue.
I am getting this error as well. I am running HomeAssistant in a Box on Unraid 7.1.2, HA Core 2025.11.2, Supervisor 2025.11.2, OS 16.3, Frontend 20251105.0. Samsung S24 Ultra, I have deleted the app from my phone, restarted the phone, removed the mobile app integration, restarted HA, and it still gives me the same error. Any direction would be appreciated. I can follow steps if given. Thank you.
I would really appreciate some direction, I am at a loss as what direction to take. I am new to Home Assistant in general. Anyone who has some free time on their hands it would be appreciated, DV here, at home 24/7. thank you.
I have figured this out myself I believe. I have a Dell server, r740xd 248gb ram, 120tb storage, running unraid, Home Assistant in a Box. I also have the Home Assistant Green. Again, I am NEW to all this, I did not realize that I was just doubling up on the HA, so the lightbulb turned on this morning in my head and I unplugged the HA green and I tried to log in the HA app on my phone, voila!, no issues getting in, I’m guessing the problem was with the HA green, which I will be returning as I have warranty. I have more than enough overhead to run the VM on my server so I will continue it that way. I am a bit saddened though, that I never got a response from anyone about my issue, I figure I will just read and learn as I go, oh well.
This was not your issue. You stomped on someone else’s issue. You should have started your own thread with your issue. Only people that responded in this thread automatically saw your posts. You completely limited the amount of very smart people that would see your question.
Heya,
I’m also experiencing this issue
I also had the mini-graph-card, card-mod and bubble card plugins in my server. I removed those.
After rebooting the home assistant, this appears to have fixed the issue. It is then probably one of those three plugins.
Should you run into this, remove those plugins, (maybe one-by-one), restart and communicate back.
Love and kisses!
Additional mark;
It appears that devices that are “revoked” this way might need to be reconnected, but one android phone app did in fact not need to be. It just asked for location permissions, and continued right on. (this device did not have its token removed).
