Hi, so i’ve done all the things necessary to access Hassio from the internet but can’t seem to get it working. The request always times out. Pinging to my Hassio from the internet doesn’t respond either.
My config is:
DuckDNS logs don’t show any errors either. Ports on router are forwarded from TCP 8123 to TCP 8123 and from TCP 443 to TCP 8123. Tried disabling one or another of them. Tried testing opened ports with canyouseeme(dot)com and indeed, they were open. Accessing hassio from local network with https is not possible, too. My ISP does not use CG-NAT. Don’t know where to move on from now. Any help appreciated. Thanks!
Thanks for your reply!
Ooops, missed that.
Printed out date from the terminal and everything was correct. Tried various config setups but none worked. What do you mean by taking a look into the certificates?
If the page can be accessed via http then https is not set up in home assistant as it disables http. That is why nginx proxy is used by some. To keep both http and https access.
Another thought is that your ISP may not allow http traffic over non standard ports. You could try forwarding port 443 to 8123 and then remove the port from your domain when you type it in the browser.
yeah, both of them, even tried moving them to the config file and changing the path in config.yaml and duckdns config, but that still didn’t do the trick
