I’ve spent countless hours trying to update my huge amount of IKEA battery powered buttons to no avail.
They tend to suck up batteries really fast.
I’ve searched the forum on how to update the firmware but nothing seems to work for me.
Details are:
Using a conbee2 stick (3m USB ext. cable) on the ZHA stack.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.11.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "x86_64",
"os_name": "Linux",
"os_version": "6.1.59",
"supervisor": "2023.11.3",
"host_os": "Home Assistant OS 11.1",
"docker_version": "24.0.6",
"chassis": "embedded",
"run_as_root": true
configuration.yaml
zha:
zigpy_config:
#source_routing: true
ota:
otau_directory: /config/zigpy_ota
ikea_provider: true
ledvance_provider: true
The specifics of my zigbee culprit IKEA device are:
TRADFRI on/off switch af IKEA of Sweden
Firmware: 0x23079631
Nwk: 0x54a7
Device Type: EndDevice
LQI: 255
RSSI: -61
Strømkilde: Battery or Unknown
Quirk: zhaquirks.ikea.twobtnremote.IkeaTradfriRemote2Btn
"attribute_name": "sw_build_id",
"value": "2.3.079"
my “\config\zigpy_ota” folder has the file:
“10005778-tradfri_onoff_controller-24.4.6-prod.ota.ota.signed”
(+ alot of other files as well.)
This FW file should bring the device up to version :
0x24040006
but it’s stuck at
0x23079631
Also to rule out battery issues during this session I have unplugged the batt. and instead powered up the IKEA button using a DC power supply.
It works fine. button presses are registered. Nothing broken so far.
So when I carry out this service command on the corresponding ieee:
(During the process I am repeatedly clicking on the on/off button on the device itself in order to prevent it from sleeping.)
service: zha_toolkit.ota_notify
ieee: REDACTED
tries: 100
I get this response:
zha_toolkit_version: v1.1.6
zigpy_version: 0.59.0
zigpy_rf_version: 0.21.1
ieee_org:
- 17
- 38
- 137
- 254
- 255
- 172
- 51
- 188
ieee: REDACTED
command: ota_notify
command_data: null
start_time: "2023-11-21T11:29:46.670724+00:00"
errors: []
params:
dir: 0
tries: 100
expect_reply: true
args: []
read_before_write: true
read_after_write: true
PAR:
cmd_id: null
endpoint_id: null
dst_endpoint_id: null
cluster_id: null
attr_id: null
attr_type: null
attr_val: null
code: null
min_interval: null
max_interval: null
reportable_change: null
dir: 0
manf: null
tries: 100
expect_reply: true
args: []
state_id: null
state_attr: null
state_value_template: null
force_update: false
allow_create: false
event_success: null
event_fail: null
event_done: null
fail_exception: false
write_if_equal: false
csvfile: null
csvlabel: null
download: null
path: null
use_cache: false
result: null
success: true
looking at the home-assitant.log file I get this:
(do note: I’ve filtered away irrelevant log entries)
2023-11-21 12:42:42.429 DEBUG (MainThread) [custom_components.zha_toolkit] event_data {'zha_toolkit_version': 'v1.1.6', 'zigpy_version': '0.59.0', 'zigpy_rf_version': '0.21.1', 'ieee_org': REDACTED, 'ieee': 'REDACTED', 'command': 'ota_notify', 'command_data': None, 'start_time': '2023-11-21T11:42:38.098264+00:00', 'errors': [], 'params': {'dir': 0, 'tries': 100, 'expect_reply': True, 'args': [], 'read_before_write': True, 'read_after_write': True}, 'PAR': {'cmd_id': None, 'endpoint_id': None, 'dst_endpoint_id': None, 'cluster_id': None, 'attr_id': None, 'attr_type': None, 'attr_val': None, 'code': None, 'min_interval': None, 'max_interval': None, 'reportable_change': None, 'dir': 0, 'manf': None, 'tries': 100, 'expect_reply': True, 'args': [], 'state_id': None, 'state_attr': None, 'state_value_template': None, 'force_update': False, 'allow_create': False, 'event_success': None, 'event_fail': None, 'event_done': None, 'fail_exception': False, 'read_before_write': True, 'read_after_write': True, 'write_if_equal': False, 'csvfile': None, 'csvlabel': None, 'download': None, 'path': None, 'use_cache': False}, 'result': None, 'success': True}
2023-11-21 12:42:42.874 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2023, 11, 21, 11, 42, 42, 874929, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x54A7), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=None, profile_id=260, cluster_id=6, data=Serialized[b'\x01\x10\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-61)
2023-11-21 12:42:42.875 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Received ZCL frame: b'\x01\x10\x01'
2023-11-21 12:42:42.875 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False), tsn=16, command_id=1, *direction=<Direction.Server_to_Client: 0>)
2023-11-21 12:42:42.875 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Decoded ZCL frame: OnOff:on()
2023-11-21 12:42:42.875 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Received command 0x01 (TSN 16): on()
2023-11-21 12:42:42.876 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] No explicit handler for cluster command 0x01: on()
2023-11-21 12:42:43.963 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2023, 11, 21, 11, 42, 43, 963019, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x54A7), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=None, profile_id=260, cluster_id=6, data=Serialized[b'\x01\x11\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-61)
2023-11-21 12:42:43.963 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Received ZCL frame: b'\x01\x11\x01'
2023-11-21 12:42:43.963 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False), tsn=17, command_id=1, *direction=<Direction.Server_to_Client: 0>)
2023-11-21 12:42:43.964 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Decoded ZCL frame: OnOff:on()
2023-11-21 12:42:43.964 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] Received command 0x01 (TSN 17): on()
2023-11-21 12:42:43.964 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0006] No explicit handler for cluster command 0x01: on()
2023-11-21 12:42:44.142 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x3F8F](lumi.sensor_magnet): Device seen - marking the device available and resetting counter
2023-11-21 12:42:44.143 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x3F8F](lumi.sensor_magnet): Update device availability - device available: True - new availability: True - changed: False
2023-11-21 12:42:44.163 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x5377](lumi.sensor_wleak.aq1): last_seen is 44279840.19995642 seconds ago and ping attempts have been exhausted, marking the device unavailable
2023-11-21 12:42:44.164 DEBUG (MainThread) [homeassistant.components.zha.core.device] [0x5377](lumi.sensor_wleak.aq1): Update device availability - device available: False - new availability: False - changed: False
2023-11-21 12:42:44.507 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2023, 11, 21, 11, 42, 44, 507041, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x54A7), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=None, profile_id=260, cluster_id=25, data=Serialized[b'\x01\x12\x06\x00|\x11\xc5\x11\x06\x00\x04$'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-61)
2023-11-21 12:42:44.507 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Received ZCL frame: b'\x01\x12\x06\x00|\x11\xc5\x11\x06\x00\x04$'
2023-11-21 12:42:44.507 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False), tsn=18, command_id=6, *direction=<Direction.Server_to_Client: 0>)
2023-11-21 12:42:44.508 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Decoded ZCL frame: Ota:upgrade_end(status=<Status.SUCCESS: 0>, manufacturer_code=4476, image_type=4549, file_version=604241926)
2023-11-21 12:42:44.508 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Received command 0x06 (TSN 18): upgrade_end(status=<Status.SUCCESS: 0>, manufacturer_code=4476, image_type=4549, file_version=604241926)
2023-11-21 12:42:44.509 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] OTA upgrade_end handler for 'IKEA of Sweden TRADFRI on/off switch': status=Status.SUCCESS, manufacturer_id=4476, image_type=4549, file_version=604241926
2023-11-21 12:42:44.509 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=True, *is_general=False), tsn=18, command_id=7, *direction=<Direction.Client_to_Server: 1>)
2023-11-21 12:42:44.509 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Sending reply: upgrade_end_response(manufacturer_code=4476, image_type=4549, file_version=604241926, current_time=0, upgrade_time=0)
2023-11-21 12:42:45.353 DEBUG (MainThread) [zigpy.application] Received a packet: ZigbeePacket(timestamp=datetime.datetime(2023, 11, 21, 11, 42, 45, 353906, tzinfo=datetime.timezone.utc), src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x54A7), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=None, profile_id=260, cluster_id=25, data=Serialized[b'\x00\x12\x0b\x07\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=255, rssi=-61)
2023-11-21 12:42:45.355 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Received ZCL frame: b'\x00\x12\x0b\x07\x01'
2023-11-21 12:42:45.355 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True), tsn=18, command_id=11, *direction=<Direction.Server_to_Client: 0>)
2023-11-21 12:42:45.356 DEBUG (MainThread) [zigpy.zcl] [0x54A7:1:0x0019] Decoded ZCL frame: Ota:Default_Response(command_id=7, status=<Status.FAILURE: 1>)
I should also mention that I have been able to update some other none-IKEA (bulbs) just fine.
But these IKEA buttons are a real nightmare.
I’ve tried to have the button connected to the coordinator directly sitting 10cm from it.
I’ve also tried to connect it through another IKEA router. A LED driver (powersupply).
Same ordeal
I guess I could just buy the official IKEA GW and have all my IKEA devices route through that.
Or buy some other zigbee buttons. Sigh.
