Unable to install HASSIO on Pi3B+
I am trying to install hassio on pi3B+ but looks like hassio is not able to connect to network.
I am trying to connect using ethernet port and I have a USB drive with network/my-network file :
[connection]
id=hassos-network
uuid=d55162b4-6152-4310-9312-8f4c54d86afa
type=802-3-ethernet
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
My IP is in the range 192.168.31.x
hassio gives an exception stack and goes in loop forever.
Please help.
I thought if you were using DHCP you didn’t need the network file on a USB?
I have tried with and without USB but I am not able to get hassio installed for some reason :frowning:
I am using the latest version - hassos_rpi3-1.11.img.gz
I tried the fing app and I dont see the IP.
hassio goes in loop with the following error :
That is not an issue with networking. The device is failing. Either SDCard or power supply, or you have a bad Pi.
I am using a 3amps power supply and its a new pi. i was able to run rasperian on it without issues.
Really out of options on what to try next :frowning:
Are you sure it’s a 3b+ and not just a 3b?
Yaa its a pi3B+
2435753657360440347
Hi, I have exactly the same experience. Has anybody successfully installed hassio on a 3B+ ?
Sure, lots of people have. It was released in July with 3b+ support.
I have tried different adapter… 8gb and 32gb SD cards, tried Ethernet and wifi…
Anything else I can try ?
try an older version.
I have tried hassos_rpi3-1.10.img.gz and it’s the same issue.
Not sure if my pi has a problem… I will try on an older pi and let you know… thanks for your inputs :slight_smile:
Any luck? Did you get it working ?
Nope. I have tried the 64 bit version as well.
I tried hassos_rpi3-1.11.img.gz 32bit and 64bit + hassos_rpi3-1.10.img.gz + hassos_rpi3-1.9.img.gz and all have the same error :
I have an old pi1 and I tried hassos_rpi-1.11.img.gz and it worked perfectly fine.
Any idea why it is failing only on pi3b+
Sorry, no idea.
Finally got installation done on Pi 3B+
Seems like 3B+ is more sensitive to the state/quality of the sd card. Used another card and running perfectly.
Thats good news… Which SD card are you using now? I have tried with sandisk ultra class10.
