It’s a VM, you have host access though your hypervisor.
hit “enter”
Ok, it gives me the login, but its too fast I can’t type docker logs hassio_supervisor that it continues with the log.
BTW the command docker gives error
EDIT I can’t even have time to do a screenshot
So to recapitulate
My proxmox is 192.168.1.13, I can SSH to it, but don’ìt know whgat to do with SSH there
My HASSIO VM is in 192.168.1.12, I cannot do SSH to it (connection refused)
My HASSIO VM in proxmox, shows a log, when I hit enter, it gives me the prompt
ha >
the command docker … does not work (unknown command docker for ha)
any other command gives connection refused
and my HASSIO is down
You need to login, so you get the #
prompt
after I cclick ENTER, I get
hassiomain login:
I put root and then click enter, like this I receive the
> ha
is not like this??
after you login, type login
Ok, now I am able to get the log docker logs hassio_supervisor but its super fast, not sure how to get the files to show. it stil same error.
EDIT with difficulty I am able to get screenshot
It is the logs in white that would be interesting, especially the last 5 lines of them
If I don’ have this issue right now, but I’m getting it often. I think there is nothing interesting in my logass for now?
Hassio was loading for about 20 minutes after I reset it by plugging the powerplug out
I am tired of Home Assistant. In my case is not worth it, really considering throwing away all of it, and going back to a non automated house, as it was for the past 30 years.
Now I deleted the VM, and will recreate a new one, hope the snapshot I have does not have the supervisor error
That particular message is due to a broken image that docker tries to use.
It has been solved in supervisor 235, these commands should fix that:
docker system prune
docker restart hassio_supervisor
When the supervisor has started up again, then run ha su repair
NB! If you are reading this and do not have the exact same message on supervisor version < 235 DO NOT run this!
I’m trying to install fresh HA supervised on a new Raspberry Pi 4 Gb pulling the latest images from the Docker Hub and I get this error right away after clean install.
Those commands do not help and if I try issuing any command to supervisor via hassio_cli
I get the following error:
Get http://supervisor/supervisor/info: dial tcp 172.30.32.2:80: connect: connection refused
Same error after clean install on a VM install
Same issue here!! Get same response from CLI.
Did you get it working?
Cant get it working anymore either, docker logs hassio_supervisor says this:
20-08-31 11:17:12 ERROR (MainThread) [supervisor.core] Detected unsupported OS: Raspbian GNU/Linux 10 (buster)
20-08-31 11:17:12 INFO (MainThread) [__main__] Run Supervisor
20-08-31 11:17:12 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-08-31 11:17:12 CRITICAL (MainThread) [supervisor.core] System running in a unsupported environment!
20-08-31 11:17:12 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' start 0 add-ons
20-08-31 11:17:12 INFO (MainThread) [supervisor.core] Supervisor reboot detected
20-08-31 11:17:12 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-08-31 11:17:12 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-08-31 11:17:12 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-08-31 11:17:12 INFO (MainThread) [supervisor.host.info] Update local host information
20-08-31 11:17:12 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-08-31 11:17:12 INFO (MainThread) [supervisor.host.services] Update service information
20-08-31 11:17:12 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-08-31 11:17:13 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-08-31 11:17:13 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-08-31 11:17:13 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
After my holiday I ran into the same error. (Home assistant was working though!)
So I tried to restart my RPI. Everything dead now. No webinterface, no ssh. It’s only responding to ping.
I only have configuration and automations configfile backupped. Should I start over again? Never had the issue, my config was faily simple.
I just turned mine on.
Any thing else we could do to provide more information to diagnose the cause(s)?
Thanks,
-Mike
