I removed asuswrt component & device tracker from configuration.yaml and restarted the home assistant docker. The asuswrt error is gone, but otherwise the log is exploding with errors:
2019-08-11 20:43:05 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function async_track_state_change.<locals>.state_change_listener at 0x7f30f0e29bf8>
File "uvloop/cbhandles.pyx", line 68, in uvloop.loop.Handle._run
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 85, in state_change_listener
event.data.get('new_state'))
File "/usr/src/homeassistant/homeassistant/core.py", line 342, in async_run_job
target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 106, in template_condition_listener
template_result = condition.async_template(hass, template, variables)
File "/usr/src/homeassistant/homeassistant/helpers/condition.py", line 331, in async_template
value = value_template.async_render(variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 191, in async_render
return self._compiled.render(kwargs).strip()
File "/usr/local/lib/python3.7/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for /: 'NoneType' and 'int'
2019-08-11 20:43:05 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function async_track_state_change.<locals>.state_change_listener at 0x7f30f0e2e048>
target(*args)
roelof@nucentral:/usr/share/hassio/homeassistant$ nano home-assistant.log ^C
roelof@nucentral:/usr/share/hassio/homeassistant$ clear
roelof@nucentral:/usr/share/hassio/homeassistant$ cat home-assistant.log
2019-08-11 20:34:15 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-11 20:34:15 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-11 20:34:15 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for breaking_changes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-11 20:34:17 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for afvalwijzer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-11 20:34:21 ERROR (MainThread) [homeassistant.components.template.cover] could not convert string to float: 'None'
2019-08-11 20:36:31 ERROR (MainThread) [custom_components.breaking_changes] Could not update data - HTTPSConnectionPool(host='hachanges.halfdecent.io', port=443): Max retries exceeded with url: /96/json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f30f1a72da0>: Failed to establish a new connection: [Errno 110] Operation timed out'))
2019-08-11 20:38:43 ERROR (MainThread) [custom_components.breaking_changes] Could not update data - HTTPSConnectionPool(host='hachanges.halfdecent.io', port=443): Max retries exceeded with url: /96/json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f30f0510898>: Failed to establish a new connection: [Errno 110] Operation timed out'))
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.trash_pmd is taking over 10 seconds
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.spotify is taking over 10 seconds
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.components.sensor] Updating afvalwijzer sensor took longer than the scheduled update interval 0:00:30
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.components.sensor] Updating spotcast sensor took longer than the scheduled update interval 0:00:30
2019-08-11 20:38:43 WARNING (MainThread) [homeassistant.components.media_player] Updating spotify media_player took longer than the scheduled update interval 0:00:30
2019-08-11 20:40:54 ERROR (MainThread) [custom_components.breaking_changes] Could not update data - HTTPSConnectionPool(host='hachanges.halfdecent.io', port=443): Max retries exceeded with url: /96/json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f30f0467ac8>: Failed to establish a new connection: [Errno 110] Operation timed out'))
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.buienradar.sensor] Unable to retrieve xml data from Buienradar.(Msg: , status: None,)
2019-08-11 20:40:54 ERROR (MainThread) [coap] Exception CancelledError() can not be represented as errno, setting -1.
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for Ouderslaapkamer Gu10 Hue 2
File "/usr/local/lib/python3.7/site-packages/pytradfri/api/aiocoap_api.py", line 95, in _get_response
r = await pr.response
File "/usr/local/lib/python3.7/site-packages/aiocoap/protocol.py", line 816, in _run_outer
yield from cls._run(app_request, response, weak_observation, protocol, log, exchange_monitor_factory)
File "/usr/local/lib/python3.7/site-packages/aiocoap/protocol.py", line 865, in _run
blockresponse = yield from blockrequest.response
aiocoap.error.RequestTimedOut
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for TRADFRI bulb E27 WS opal 980lm 6
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for TRADFRI bulb GU10 WS 400lm 2
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for Ouderslaapkamer Gu10 Hue 1
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for Leeslamp onderste
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for TRADFRI bulb E14 W op/ch 400lm 2
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for Trapkast
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for Leeslamp bovenste
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for TRADFRI bulb E27 WS clear 950lm
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for Ouderslaapkamer Gu10 Hue 3
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for TRADFRI bulb GU10 WS 400lm 3
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for TRADFRI bulb E27 WS opal 980lm 2
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for Leeslamp middelste
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.light] Observation failed for TRADFRI bulb E27 W opal 1000lm 3
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.sensor] Observation failed for Leeslamp remote
2019-08-11 20:40:54 WARNING (MainThread) [homeassistant.components.tradfri.sensor] Observation failed for Ouderslaapkamer remote
2019-08-11 20:40:54 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function async_track_state_change.<locals>.state_change_listener at 0x7f30f0e29bf8>
target(*args)
2019-08-11 20:40:54 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function async_track_state_change.<locals>.state_change_listener at 0x7f30f0e2e048>
target(*args)
2019-08-11 20:43:05 ERROR (MainThread) [custom_components.breaking_changes] Could not update data - HTTPSConnectionPool(host='hachanges.halfdecent.io', port=443): Max retries exceeded with url: /96/json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f30ef9c00b8>: Failed to establish a new connection: [Errno 110] Operation timed out'))
2019-08-11 20:43:05 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.chromecast_devices is taking over 10 seconds
2019-08-11 20:43:05 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.spotify is taking over 10 seconds
2019-08-11 20:43:05 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function Request.send_request.<locals>.timeout_request at 0x7f30f0b34c80>
File "uvloop/cbhandles.pyx", line 261, in uvloop.loop.TimerHandle._run
File "/usr/local/lib/python3.7/site-packages/aiocoap/protocol.py", line 732, in timeout_request
del self.protocol.outgoing_requests[(request.token, request.remote)]
KeyError: (b'\x00\x00>\x1a', <aiocoap.transports.tinydtls.DTLSClientConnection object at 0x7f30f07ac588>)
2019-08-11 20:43:05 WARNING (MainThread) [homeassistant.components.sensor] Updating spotcast sensor took longer than the scheduled update interval 0:00:30
2019-08-11 20:43:05 WARNING (MainThread) [homeassistant.components.media_player] Updating spotify media_player took longer than the scheduled update interval 0:00:30
2019-08-11 20:43:05 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/pytradfri/api/aiocoap_api.py", line 155, in request
result = await self._execute(api_commands)
File "/usr/local/lib/python3.7/site-packages/pytradfri/api/aiocoap_api.py", line 114, in _execute
await self._observe(api_command)
File "/usr/local/lib/python3.7/site-packages/pytradfri/api/aiocoap_api.py", line 172, in _observe
pr, r = await self._get_response(msg)
File "/usr/local/lib/python3.7/site-packages/pytradfri/api/aiocoap_api.py", line 100, in _get_response
await self._reset_protocol(e)
File "/usr/local/lib/python3.7/site-packages/pytradfri/api/aiocoap_api.py", line 78, in _reset_protocol
await protocol.shutdown()
File "/usr/local/lib/python3.7/site-packages/aiocoap/protocol.py", line 133, in shutdown
for exchange_monitor, cancellable in self._active_exchanges.values():
AttributeError: 'NoneType' object has no attribute 'values'
(log is too long to paste entirely here)
Can you please help me on my way to restore a snapshot?
