Unable to Separate Devices in Automation
I have a ceiling fan/light that’s integrated into HA via the Bond integration. I’m trying to establish a “Scene” that, among other devices, controls the light. I’m unable to add the light without the fan being added as well. When searching for the light (device), the only item the returns is the ceiling fan. Once I select the fan, both light and ceiling fan switches are added to the scene;
I’ve tried modifying scenes.yaml directly, removing the fan, but it doesn’t prevent the ceiling fan from being added again when the Scene is edited. I’d like to add just the ceiling light but cannot figure out how to do so. I tried using the “Add an entity” field to add just the light but once saved, the entity, including the fan, is added to the device list.
I’m wondering if this may be a problem with either the scene editor or the integration. I’m leaning more toward the scene editor as when setting up “Scenes” using Kasa light switches, the LED associated with the switch is also added. I’m also noticing the same behaviour when using the “Automation” editor.
I did find the light can be operated on it’s own through a script. Does this mean I should be using scripts instead of scenes for these devices?
I’m running into the same thing (also with Bond). I also want to control the fan and light independently of each other in a scene. I would suspect this is unintended since there they can be controlled independent of each other. Maybe due to the organization of the Bond integration entities in HA.
