I have setup 3 Honeywell Lyric T6 Pro thermostats (TH6320ZW2003) and they all seem to be functioning and communicating fine except for the target temperature.
When I try to set the target temp the temperature turns red (pictured below) and then flips back to the current temperature. I should note that my current workaround is to have manually set the target temp on the device for Home/Away preset mode and just toggle between the two. As such, this doesn’t seem to even be reading in the correct target temperature of the device and is just displaying the current temperature.
I don’t know much about the inner workings of Zwave, but when I’m doing the above, this is what is printed out of the logs in the zwave integration:
2019-10-06 09:21:56.346 Info, Node003, Value::Set - COMMAND_CLASS_THERMOSTAT_SETPOINT - Dry Air - 8 - 1 - 18
2019-10-06 09:21:56.347 Detail, Node003, Queuing (Send) ThermostatSetpointCmd_Set (Node=3): 0x01, 0x0c, 0x00, 0x13, 0x03, 0x05, 0x43, 0x01, 0x08, 0x01, 0x12, 0x25, 0x49, 0xd3
2019-10-06 09:21:56.347 Detail, Node003, Queuing (Send) ThermostatSetpointCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x43, 0x02, 0x08, 0x25, 0x4a, 0xc0
2019-10-06 09:21:56.347 Info, Node003, Sending (Send) message (Callback ID=0x49, Expected Reply=0x13) - ThermostatSetpointCmd_Set (Node=3): 0x01, 0x0c, 0x00, 0x13, 0x03, 0x05, 0x43, 0x01, 0x08, 0x01, 0x12, 0x25, 0x49, 0xd3
2019-10-06 09:21:56.356 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-06 09:21:56.359 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-06 09:21:56.371 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x49, 0x00, 0x00, 0x02, 0xa0
2019-10-06 09:21:56.372 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x49 received (expected 0x49)
2019-10-06 09:21:56.372 Info, Node003, Request RTT 24 Average Request RTT 37
2019-10-06 09:21:56.372 Detail, Expected callbackId was received
2019-10-06 09:21:56.372 Detail, Expected reply was received
2019-10-06 09:21:56.372 Detail, Message transaction complete
2019-10-06 09:21:56.372 Detail, Node003, Removing current message
2019-10-06 09:21:56.372 Info, Node003, Sending (Send) message (Callback ID=0x4a, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x43, 0x02, 0x08, 0x25, 0x4a, 0xc0
2019-10-06 09:21:56.380 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-06 09:21:56.381 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-06 09:21:56.397 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x4a, 0x00, 0x00, 0x02, 0xa3
2019-10-06 09:21:56.397 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x4a received (expected 0x4a)
2019-10-06 09:21:56.397 Info, Node003, Request RTT 24 Average Request RTT 30
2019-10-06 09:21:56.398 Detail, Expected callbackId was received
2019-10-06 09:21:56.415 Detail, Node003, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x03, 0x06, 0x43, 0x03, 0x00, 0x22, 0xff, 0x4c, 0x23
2019-10-06 09:21:56.415 Info, Node003, Response RTT 42 Average Response RTT 117
2019-10-06 09:21:56.415 Detail, Node003, Expected reply and command class was received
2019-10-06 09:21:56.416 Detail, Node003, Message transaction complete
2019-10-06 09:21:56.416 Detail, Node003, Removing current message
If you have any insight into the issue I’m having or are just able to point me in the right direction to get this sorted out it would be much appreciated. Thanks!
