That definitely explains why it times out, thanks! Removed it now.
I should have been more clear in my previous message. After the wait_template
I have this step, which doesn’t work.
service: media_player.play_media
media_content_type: EPISODE
media_content_id: >-
"library_name" : "TV shows",
"show_name": "Bing",
"shuffle": 1,
"maxresults": 1
enqueue: replace
entity_id: media_player.plex_plex_for_apple_tv_apple_tv
Plex doesn’t do anything. Just sits on the home page.
I do get this error in the logs:
[139662584965696] Client is not currently accepting playback controls: Plex (Plex for Apple TV - Apple TV)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 230, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2035, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2072, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 605, in _service_handler
response = await self._async_start_run(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 563, in _async_start_run
script_result = await coro
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 594, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1578, in async_run
return await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 420, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 470, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 493, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 704, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 666, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 876, in entity_service_call
response_data = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 948, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 799, in async_play_media
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/plex/media_player.py", line 487, in play_media
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Client is not currently accepting playback controls: Plex (Plex for Apple TV - Apple TV)
No idea why it will not accept playback controls. No firewall in place, both are on the same network/VLAN.
I tried setting up the Plex integration locally (via IP address) and via plex.tv. Both yield the same result.
I’m running the latest version of HA and tvOS.
