Unable to update, supervised install - no internet connection
I am trying to run an update, which I neglected for some time. I am now on core 2022.9.6 trying to move to 2022.11.1. I am getting no internet error in logs:
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, no host internet connection
I googled a lot, but nothing works, seems that supervisor is getting false connection status - is there a way to force it to ignore connectivity status?
Server is connected, all is up an running, I am just stuck with the update.
I see unsupported status, which is driven by systemd-journal, but I gave up trying to solve it. Perhaps this is connected?
Systemd error below:
ERROR (MainThread) [supervisor.host.logs] No systemd-journal-gatewayd Unix socket available
  • Go to Settings > System > Network.
  • Confirm the settings for IPv4 are correct (or IPv6 if that’s what you’re using on your local network.
It’s all correct, I tried to change DNS from my default router to 8.8.8.8. I have changed from auto to manual, etc. no luck
Managed to solve this it seems.
nmcli g status showed “portal” under CONNECTIVITY column. I am not using wifi for connection, but still, it seems it affected the connectivity check. I have commented out all lines in file /etc/NetworkManager/conf.d/20-connectivity.conf and rebooted the machine. After rebooting, I could see “full” under CONNECTIVITY in nmcli g status output and all updates went fine.
I did an update on HA was getting a the same no internet connection. I run a supervised install. Checking “nmcli g status” showed “limited” connectivity even though there were no network issues. On my system I had set a static IP address using /etc/network/interfaces. I believe this was why NetworkManager reported “limited” connectivity. So I reconfigured networking so NetworkManager would assigned the static address. This then change the reported connectivity to “full”. At which point the error in HA went away. So thanks for the hint. The steps I took are documented here.
Try to install systemd-journal-remote
Did you ever get to the bottom of this? I’m having a similar issue and cannot get it fixed no matter what I try.
For me a simple restart helped. The complete one…
Got the same issue and this how I get it solved:
  1. SSH to your machine
  2. Ping for any external resource, if OK, then go to next step
  3. type in terminal nmcli g status. On this step i got STATE: disconnected, but in fact the internet connection was OK.
  4. Nmcli is NetworkManager tool. I,m using netplan on my machine, so I checked my netplan config (/etc/netplan/***.yaml) and added string renderer: NetworkManager
  5. Next type sudo netplan apply and recheck status with nmcli g status, now got the status connected, so this what worked for me.
Evening,
I am new to docker but not new to linux. I followed the instructions here official instructions but when I got to the point of installing home assistant (dpkg -i homeassistant-supervised.deb) it would just loop with 100% packet loss.
error:
PING checkonline.home-assistant.io (172.67.68.90) 56(84) bytes of data.
--- checkonline.home-assistant.io ping statistics ---
1 packets transmitted, 0 received, 100% packet loss, time 0ms
When I run “nmcli g status” from the host I get
state          connectivity    wifi-hw     wifi         wwan-hw    wwan
connected      full            enabled    enabled       enabled     enabled
when I run “docker network ls” I get
network id   name      driver    scope
<id>         bridge    bridge    local
<id>         host        host     local
<id>         none      null      local
There are no containers in docker. Debian is a fresh install and I followed the steps. Does anyone know how to fix this?
*I have ha installed on an old raspberry pi 3, I am setting this up on debian for a friend. Compared to the complications around this supervised setup and following the official instructions exactly and still can’t get it working, I would happily change to a non-supervised version of ha if someone can point me to where instructions are for doing that
I was able to sort it out. Here is the solution that worked for me.
  • run all of the commands in the official installation up until section 3 - Install Home Assistant Supervised
  • run the command for docker in the ODROID - Home Assistant instructions
docker run -d \
  --name homeassistant \
  --privileged \
  --restart=unless-stopped \
  -e TZ=MY_TIME_ZONE \
  -v /PATH_TO_YOUR_CONFIG:/config \
  --network=host \
  ghcr.io/home-assistant/home-assistant:stable
After the docker install command was complete, I ran ifconfig to get my ip address for the host. On the same wifi, went to the home assistant port with that ip address and had access.
Hope this helps someone else!
After a lot more knowledge tranfer from google fu, I was able to determine root cause of supervised installation not working. For some reason the ethernet port on the board I installed debian on wasn’t working (orange pi 3 lts…apparently a known issue). When connected to wifi, during the home assistant install step the network cuts out and then back on, which caused the loop issue because the setup process for some reason wouldn’t recognize the reestablished connection.
So, fixing the ethernet port issue and not attempting to run the supervised setup over wifi. The install step I found above is just for the container install. So no addon store. Which means getting zwave to work is a pita, but I did find a good walk thru here
I hope all of this helps the next person. I spent almost a week trying to hunt all of this down
I’m sad to confirm that it’s indeed likely a DNS issue. I was using pi-hole but the container failed to restart so everything here fell apart because I didn’t add a redundant DNS server option.
Seam to be having a similar issue,
I have checked my DNS settings, but again, im unable to update from, 2023/9/0 to 2023/9/3
Please don’t cross post! :wink: It makes helping very difficult. :wink: If you can’t find a topic, where your question fits, please open your own topic. :slight_smile:
My upmost apologies.
Im going a little cross eyed here trying to work this out.
Think it may be time to quit for the evening.
If you are still awake enough, open up a new topic, so others can give some input until tomorrow morning. :wink:
a late reply but I just experienced this same issue and found a simple fix that worked in my case that will hopefully help someone in the future having this issue. I was also experiencing the issue where an update would fault with a ‘no internet connection’ error and nmcli g status showed limited connectivity despite full network connectivity working perfectly.
My simple fix was to connect to HA via the console (I’m running HA as a VM on ESXi), and follow the wiki steps to default the network settings back to defaults, allow it to pull a DHCP address then set a static IP back to what it was before the error. All of the steps I followed ar in this article. operating-system/Documentation/network.md at 5eb7ccb7611a06a00013d4292b5e8bd75147195d · home-assistant/operating-system · GitHub
Hope this helps someone else in the future!
Is this for HAOS or home assistant supervised?
