OK, yeah that’s the ‘usual’ layout problem that always appeared on iOS. It renders differently than on any other browser I ever tested, with more spacing around the text and buttons. No idea why. I don’t have an iOS device, so unfortunately I can’t debug this.
Once you have the override enabled, you can hide the menu again.
Is it possible to remove fill color from all infopanel curves? And also set default curve color. Looks like it works only when done separately for each entity?
You can set the defaults in entityOptions for entire device classes too. For example, to change the defaults for sensors in the temperature device class:
infoPanel:
entityOptions:
temperature:
color: red
fill: '#00000000'
It probably would make sense to add the support for entire domains too. stateColors can do domain wide overrides after all.
Putting just the fill line alone after infoPanel doesn’t seem to work. It only works when there are entityoptions and even then it works only for that entity.
This doesn’t work:
infoPanel:
fill: '#00000000'
this works, but only for temperature:
infoPanel:
fill: '#00000000'
entityOptions:
temperature:
color: green
Just tried this and I am amazed. Just fantastic! Most useful card ever!
Question:
If I use
toolbar: hide
selector: hide
on a card, it works fine.
But the toolbar is still visible in more-info.
Can I hide it in more-info as well?
I like to keep the UI clean and hide a lot of other objects in the more-info and since you have the amazing zoom function with CTRL+mouse roll and timeline click 'n slide, I don’t need the toolbar.
I originally planned to do this right from the start, but the strange way the HA frontend manages dialogs prevented me from doing it the same way than the other config. In very simple terms, HA dialogs (like the more info popup) have a render and an update function. Render creates the html you see on the popup, including the buttons, the graphs, etc. Update tells the dialog code how it should render (depending on the entity type, etc). Now, the problem is, render is called before update… So we have a chicken and egg problem. It would render the button for a fraction of a second, before realizing (in the subsequent update call) that it doesn’t need them. So they would flash briefly. It’s a design flaw in the HA frontend.
Configurable UI elements will have to be handled apart from the other config. I’ll think about how I could do this.
Thanks for the explaination.
I know all kinds of reverse engineering takes a lot of time, and this one’s just a nice to have
I haven’t tried yet, but I guess I could hide it with card-mod like I hide a lot of other elements instead.
Most UI config options should now work for more info panels too (color and graph height overrides, hide toolbar, invert zoom buttons, etc). @arganto@boneheadfraggle
You can now also do domain wide rules for entityOptions in addition to device_class and entities. The order of priority for the override is - entity first, then device class and domain last. This works for the custom card as well as for the more info panel. If, for example, you want red lines without fill for all your sensors by default in the more info panel, except for humidity which should be green: (@TimoJ)
infoPanel:
entityOptions:
color: red
fill: '#00000000'
humidity:
color: green
fill: '#00ff0010'
You can now hide entity name labels from tooltips if you want them even more compact. See readme under tooltips. You might notice that the YAML format for tooltip options has changed a bit to make it cleaner. You can change your current tooltip settings to the new format if you want, but you don’t have to. The old settings will keep working (forever).
And some clipping fixes to the more info panel on Chrome and derivatives (Edge, Chromium, Vivaldi, etc).
The info panel is an entirely different instance of the card. Think of it as a ‘virtual’ history explorer card. You need to configure it just as you configured a normal custom history explorer card, if the defaults don’t work for you.
You add the config for the info panel into the YAML of any other history explorer card you have on your dashboard (maybe the one you used to enable the info panel override).
