I’m not really sure I fully understand your issue. Multiple HE cards should never influence each other as long as they have a unique card name, as explained under multiple cards.. This is not optional if you have multiple cards. Without unique names, the cards cannot differentiate their config from your browser cache. When creating cards over the UI, a unique name is auto generated. If you do it manually in the Lovelace YAML, you need to add a unique name yourself.
Correct.
Yeah I think I know where the problem is. I think it’s something stupid I did. That’s from doing this late when tired Should be an easy fix.
In the general card, you can override the graph type using entityOptions or in the YAML. In the more info, that’s currently not possible, due to the weird way the HA popup dialog separates rendering and updating.
Unfortunately, that’s not technically possible. A custom frontend card has only access to its own config. It cannot access any other config.
Yeah, not all entity options work yet. More will come in the next release.
Indeed.
Not at this time.
It does auto resize. Is there a very large value somewhere right outside of the view if you scroll left or right ? The auto resize will sometimes take in some values that are out of view of ± 24h. That’s unavoidable.
When I find some time, yeah
Well, it’s not really in the scope of this card, sorry.
It uses whatever your recorder is set to. If you want more, either increase your recorder retention period or enable long term statistics, which will be merged in realtime with your recorder in the graph:
I’ve got two separate graphs here, and would like to temp and humidity be in one graph. I’ve named the card with a specific name. What am I doing wrong?
Thanks, was confusing that and another part of the read me. Honestly hadn’t gotten to that part of it yet. Don’t have a second temp sensor yet but when I do I’ll try out the multiple lines
Just noticed this. Not sure if related, but keep in mind that the override on/off is a per-browser setting. You will have to explicitly enable it on every browser (or app) you use HA on, as it is stored in the browser local storage.
V1.0.33 should fix some problems encountered with the more info panel override:
The problem with the more info config and multiple history explorer cards should have improved. If you have multiple HE cards, then make sure to only add the infoPanel option to a single HE card. Don’t add it to multiple cards, not even an empty infoPanel key. @Mariusthvdb, can you check if this improves your situation (after having given each card a unique name) ? You might have to reenable the override in the menu after applying the update.
Better layout on mobile browsers (toolbar should not overlap anymore)
entityOptions should now support settings like ymin and ymax (@derflob).
tbh, I dont understand that… how do I set it explicitly on iOS app browser? The config is a per card setting isnt it in the Yaml mode config? not a per browser setting?
As I showed above, the setting is activated because of the card it uses in that dashboard, what more could I do to explicitly enable that? (see below for exact yaml)
btw, Ive just updated to 1.0.34, and still see the oddly placed toolbar dropdown in the iOS app too. And no HE more info panel anywhere. I did refresh, kill app, even refresh frontend cache via the settings/app/error-tracking menu option
full disclosure:
I have 1 dashboard view panel HE card (has a unique name):
- title: History
icon: mdi:history
path: history
type: panel
cards:
- type: custom:history-explorer-card
cardName: history-panel-view
showUnavailable: false
recordedEntitiesOnly: true
lineMode: stepped
uiLayout:
selector: top
toolbar: both
and 1 HE card inside another dashboard, also with a unique name:
header: 3 Fase totaal
cardName: 3-Fase-totaal
uiLayout:
# toolbar: hide
selector: hide
lineMode: stepped
graphs:
- type: line
entities:
- entity: sensor.calculated_totaal_l1_power
- entity: sensor.calculated_totaal_l2_power
- entity: sensor.calculated_totaal_l3_power
# globally used in more-info panels
infoPanel:
lineMode: stepped
this last card is supposed to take care of the more-info panel override, at least as far as I understand it?
please let me ask something entirely different, for which I have been looking for some time now. Silly me, there’s no way I can imagine how to do what I am looking for…
having these sunchance forecast sensors for the next few days, they are actual entities, and not attributes. I would love to represent them in a way, that shows 1 graph, with a line connecting them. Would this be possible with a detailed setting in a HE card? (aware they are not historic values, but current…)
By using ‘Enable history info panel’ in the UI dropdown menu, from the HE card you have the infoPanel config attached to. From your iOS app.
OK, let me try to explain this. The info panel override is a global component. It affects the entire frontend, regardless of whether or not you have a HE card somewhere on it. But due to the way the HA frontend is designed code wise, there is no way for a global component to get any kind of user config. None. Nothing. Nada.
Only custom cards get YAML config. So you have to tie the global component to a custom card somehow, even if conceptually it doesn’t make sense. So to get the user config. But the problems don’t end there. Again, due to another weird design choice of the HA frontend, custom cards can only read their user YAML when they’re visible, ie. when you navigate to the dashboard and tab that contains the custom card. So in this case, it would mean for the override to be customized, you would need a HE card on every single tab of every single dashboard you have. And all of these HE cards would have to have a copy of the infoPanel section. Not really practical.
So the only way to configure a global frontend component at any time and any place, is to store the user config in the browser, locally. When a HE card loads its infoPanel section, it will copy it into a special config space in your browser. Which in turn will then be used by the global more info override code. This copying process is initially activated by using the ‘Enable history info panel’ option. This will prepare the local storage on your browser for the config and copy it over from the YAML. Then, every time you modify the infoPanel YAML on the HE card, the card will update the local browser storage to match your changes. You could even delete the infoPanel section entirely and the override would keep its last config on that browser.
Complicated and annoying, yes. But the way the frontend is designed, there’s no other way to do this.
