I have this problems, what could I do?
I can’t update homeassistant supervisor or homeassistant core, they both give me error.
I tried the solution to this link Supervisor was not able to update - Home Assistant but doesn’t work
Try this:
ha supervisor repair
Also which version are you running?
I tried and after “command completely successfully” the ha res info command makes the same output as above.
Home Assistant Core 2022.11.4
Home Assistant Supervisor 2022.11.2
Ah there is a specific issue with that version let me find it…
EDIT: no actually the issue was with 2022.11.0, Supervisor November beta issue impacting users on Home Assistant beta/dev channels
So it is unrelated and that won’t help.
What is your DNS set to?
Try 1.1.1.1
Seems to be related to backup.
Do you have enough space for a backup?
