It depends :
you have to look at the Mac id on the device itself and not the Mac id that you can see like from an ip scanner.
At first I copied also the Mac id from a device ip scanner and that was different (= capitals & lowercase) than the one on the device itself
I’m having the same issue. Verified that the site was correct, that the account used for the integration has admin permissions in Unifi controller. Double checked the mac addesses, tried upper and lower case. I can’t figure out why the block switches aren’t showing up for any of them. Also, not seeing anything in the logs indicating that there is an issue with Unifi.
I am reworking the data fetching of UniFi integration right now and will revisit block switches after that. I will try to add frontend support for it so we don’t need to evaluate if the configuration is properly defined in configuration.yaml
Anyone else having issues with block switches after the 106.2 update? my switch no longer turns off - it just toggles back on again after i turn it off. At times it does disable the internet but it’s harder to tell now if the deivce is blocked on the internet or now maybe it’s something i have missed in the breaking changes.
Before the fix my switches toggled back on when blocking. After the fix they toggle back off when unblocking…
The device tracker status switches back to home but since the switch toggles back to off I cannot block the device again
it is working for me it’s only that switching is a little different - but it does definatly block the connection which is good - thanks for resolving that.
