Unifi Guest WiFi Voucher Generator for Home Assistant
Guest Wi-Fi vouchers from Home Assistant, in one tap
Every time someone visits, the same thing happens. They ask for the Wi-Fi, and I either
read out a long password or open the UniFi console, dig through Hotspot settings, create a
voucher, and copy the code across. It works, but it’s five minutes of clicking for
something I do every week.
So I built a Home Assistant add-on for it: Unifi Guest Wi-Fi Voucher Generator. It
creates UniFi hotspot vouchers from the Home Assistant sidebar, from a dashboard card, or
from an automation. It’s free and open source:
github.com/imne/unifi-guest-wifi-ha-addon.
What it does
You pick how many tokens you want and how long each should last, from one hour to thirty
days. Press Generate Tokens and the codes appear, ready to copy, download as a CSV, or
print as cut-out cards for the fridge.
A token’s lifetime starts when the guest first logs in, not when you create it. You can
make a handful on Monday for a weekend visit and none of them burn down early.
Below the generator is a list of recent tokens. Each one shows whether it is still
unused, in use (and until when), or expired, along with the note you gave it. The bin
icon revokes a token, which is handy when the plumber has left.
Setting it up
The add-on talks to your UniFi console through its official API, so it needs two things:
the console’s address and an API key. You create the key in UniFi Network under
Settings → Control Plane → Integrations.
You can enter both on the add-on’s Configuration tab. Or leave them empty, and the app
asks for them the first time you open it. Either way it tests the connection before saving
and tells you plainly what’s wrong: unreachable address, rejected key, or a certificate
problem.
The key stays on your Home Assistant machine. The app never shows it again and never sends
it to the browser.
A card for your dashboard
The add-on also installs a Guest WiFi dashboard card. It shows the latest token in
large type with a Copy button, and makes a new one with a single tap. It suits a wall
tablet in the hallway.
The card can list a short history of recent tokens with the same status badges. A
History switch on the card turns that list on or off, and each device remembers its
own choice, so a wall tablet can stay minimal while your phone shows everything.
Tokens from automations
The repository also includes a script blueprint that creates a
token and hands the code back to whatever called it. That means an automation can make a
token and do something with it in the next step:
actions:
  - action: script.guest_wifi_generate_token
      lifetime_minutes: 1440
      note: Front door
    response_variable: wifi
  - action: notify.mobile_app_my_phone
      message: "Guest Wi-Fi code: {{ wifi.code }}"
Some things you could build on that:
  • Send a fresh code to your phone when you switch on a “guests” toggle.
  • Put a new code on an e-ink display every morning.
  • Message a code to your Airbnb guest on check-in day.
If something goes wrong, wifi.error says what, so the automation can tell you instead of
failing silently. As a safety net, automations can create at most 60 tokens an hour.
Installing it
  1. In Home Assistant, go to Settings → Add-ons → Add-on Store → ⋮ → Repositories and
    add https://github.com/imne/unifi-guest-wifi-ha-addon.
  2. Install Unifi Guest Wi-Fi Voucher Generator and start it.
  3. Turn on Show in sidebar, open Guest WiFi, and connect your router.
It needs a UniFi console with the Network integration API (UniFi Network 9 or later) and a
guest network that uses the hotspot portal with vouchers.
Good to know
  • By default only Home Assistant administrators see the sidebar panel. For everyone else,
    the dashboard card can be set up to work through the blueprint script.
  • Token codes are stored in two Home Assistant sensors so the card and automations can read
    them. Anyone who can see entities in your Home Assistant can see the codes.
  • The add-on only lists and revokes tokens it created itself. Vouchers you made in the
    UniFi console are left alone.
Every release comes with notes on what changed, both in Home Assistant’s update dialog and
on the releases page. If you
try it and something doesn’t work, open an issue on GitHub.
It’s a lot easier to just use a QR code.
This is for people like me who opted to use vouchers for their guest wifi network instead of a static password, each voucher is unique to that specific session and lasts for whatever set time. so that once guests leave, whenever they come back they don’t automatically get on my network
I agree a QR code is easier, but this is safer and, dare I say it, way cooler.
finally someone who gets it, I can do “JUST a QR” for my home network, but where’s the nerdy/geeky fun in that :rofl:
the wifi sign in page must ask for a one time code, that’s just for that session, and expires after a certain period :zany_face:
Ah, I see now. Thanks.
Just know that Apps have taken the place of add-ons many months ago now. It is confusing having new Apps with the wrong nomenclature.
Also Your Install:
cannot work as the links are all different. Please consider testing that process again so users will be successful installing your stuff.
This may help with that process: My Link / EZ-Button to help users install your App / Marketplace Item
