Unit for temperature is % rather than °F when graphed
I’m just starting to use templates so maybe I’m doing something wrong…
I’m trying to graph outside and inside temperature with a History Graph card.
I had to make a template for the sensors using weather.home (outside temp) and climate.thermostat (inside temp)
    sensors:
      current_outside_temperature:
        friendly_name: Current Outside Temperature
        value_template: "{{ state_attr('weather.home','temperature') }}"
        unit_of_measurement: "°F"
      current_inside_temperature:
        friendly_name: Current Inside Temperature
        value_template: "{{ state_attr('climate.thermostat','current_temperature') }}"
Both units are in °F but when I graph them, the Inside Temperature is using % and Outside Temperature is using °F.
When I originally made the template I think I accidentally had the unit for Inside Temperature as % (I had copied the code from a humidity sensor), but I have since fixed it and restarted HA.
Any ideas?
Try this:
    sensors:
    sensors:
For the one showing %, it is probably the first entries in your database use %, and applies it to any graph.
You can delete them via sql, or wait for them to drop out of the database after your purge_keep_days expires.
I also find I have more control over my graphs using this:
That will not solve the problem.
