Unit [email protected] not found
I was just installing homebridge and homebridge-assistant and I decided to restart and I accidentally did this command:
“sudo nano sudo systemctl stop [email protected]
instead of:
“sudo systemctl stop [email protected]
I noticed it gave me some daemon refresh and now I can’t run it.
Edit:
So I can now no longer run the automated service and have to run it manually. Does anyone know of a fix? I would definitely appreciate it!
Edit 2:
I figured it out.
What I did:
cd /etc/systemd/system
sudo nano [email protected]
input this:
[Unit]
Description=Home Assistant
After=network.target
[Service]
Type=simple
User=%i
ExecStart=/srv/homeassistant/bin/hass -c "/home/homeassistant/.homeassistant"
[Install]
WantedBy=multi-user.target
saved it
did a daemon reload
sudo systemctl --system daemon-reload
then I could use this again:
sudo systemctl start home-assistant@homeassistant
Thanks! I’m not sure what happened, but i woke up this morning with this issue. I followed the steps you posted and I’m back up and running.
I’m glad to hear that and I was able to help! :slight_smile:
Just installed PS4-Waker and got the same issue? Service completely removed…
anyways… followed your guide and all i can say… is Thanks buddy!
Installed npm and had the same issue, all fixed with your instructions. Thanks!
Thanks, my config file disappeared as well after an npm install (why???) to get dasher installed. Your instructions got my installation working again!
This actually helped me rebuild the home-assistant service after the installation of node-red broke the home-assistant service!
Thanks!
Thanks. Worked well for me today after I shut off my server and moved it into a different closet.
Happened to me on a fresh install of HA on top of Raspbian Lite. The iOS app had a tokenmanager error. After searching this forum found you!
