Sudo: hassbian-config: command not found
Hey,
So i have recently installed Hassbian on a raspberry pi 3 after about a year of running quite happily on windows. I’ve always wanted to move away from windows and after helping a friend setup a raspberry pi, as a thanks he bought me one!
Anyways, I was running fine for a week, ran various hassbian-config scripts to install samba shares etc and all seemed fine. The only thing i had left to port was my amazon dash buttons. After a quick google i came across dasher: GitHub - maddox/dasher: 🔘 A simple way to bridge your Amazon Dash buttons to HTTP services
Installation went fine and i was up and I used the guide to setup dasher to auto-start:
Then after a reboot and I found that homeassistant was no longer?! It was just not booting. Dasher was working great but no hass?!
After a bit of searching, I found this:
This got me back up and running with hass and dasher all at startup but it seems by Hassbian scripts are now gone. If i try and run anything from GitHub - home-assistant/hassbian-scripts: Scripts used in the Hassbian image. like sudo hassbian-config install samba or sudo hassbian-config upgrade hassbian, nothing works and I just get " sudo: hassbian-config: command not found"
Any ideas?!
Please?!?! :slight_smile:
Hopefully it’ll help someone else but I have fixed it myself.
Just wanted to say thanks as I had this exact same scenario today. Minor point that the hyphens and underscores have to match in the wget and the dpkg commands, i.e. - hassbian_scripts-0.6.deb vs hassbian-scripts_0.6.deb
Also, in my case, I found that I also had to do ‘sudo systemctl --system daemon-reload’ in order to get the homeassistant service back again for some reason.
Anyway. Thanks again!
You helped me! Thanks!
Another metode that will allways download the latest version:
$ curl https://api.github.com/repos/home-assistant/hassbian-scripts/releases/latest | grep “browser_download_url.deb" | cut -d : -f 2,3 | tr -d " | wget -qi -
$ HASSBIAN_PACKAGE=$(echo hassbian
.deb)
$ sudo apt install -y /tmp/”$HASSBIAN_PACKAGE"
$ sudo rm “$HASSBIAN_PACKAGE”
$ sudo systemctl daemon-reload
Thank you so much, you saved my time!
also wanted to thank you!!
as an Australian I have noted that my timezone seems to be causing my network connectivity problems (including possibly this failure at first boot)
to those also stuck on this - check you timezone is setup correctly as this resolved much of these issues for me after downloading hass manually…
thanks very much, work for me
