On the workbench it worked. But returning it to the facility is as if there is no pulse.
The installation is as it was before tasmotizing. I have measured in the connection of the Moes and between N and Siwtch there is 110v. Once pressed 220v.
I also know that the switch “reads it” because when I do several on/off it emits beeps
Any indication?
I answer myself in part:
I have tasmotized another switch very similar to the Moes MS104. I don’t know what model it is. But electronics is very similar, not the same.
It looks the same as the one in the PDF I mentioned a few days ago, but I remember that this is not Moes.
I have put an ESP8266 just like with the same process as the Moes.
In the Tasmota console I have configured GPIO12 with Relay and GPIO13 as button. Connected and running!
From what I understand that this configuration works only with the web switch (relay). You have to find the configuration to make the Moes MS-104 work with the relay and switch!
Thanks for the help!
Thanks for trying, trouble with aftermarket/open source firmware is you have to reverse engineer and re-implement all the required functions according the the coding standards of the new platform whether it’s esphome or tasmota I’m having similar issues with shelly dimmer 2 which was working fine using older firmware now the push switch does not respond also trying to figure out all the tuya codes for a Skydance S1-B(WT). Helps to have the right tools like a multimeter or oscilloscope and also reading serial data and checking the unit against the original firmware
Hi guys, something’s odd about this one, gpio02 is for the esp12 blue led, so this leaves only tx & rx pins.
Also swapped with esp12f & esp12s but I still can’t get button 2 to work if I assign gpio01 or gpio03
I swapped back the wb3s chip (beken) and button 2 works just fine which rules out if i accidently severed any connection when i was desoldering it.
Well, I managed to tasmotize the ones that weren’t ms-104. Once the chip and firmware were changed, it worked the first time.
The MS-104 I have not been able to make them work. Neither with pulses, nor anything…
The delay happens with Moes MS-104B. I assume you’ve tested with other hardware, not MS-104B. Am I correct? It seems to be something related to this model.
Congrats on writing the guide. OpenBK7231T seems to be a promising project.
The issues I have are, if operated from either the RF remote or AC Push button. the statuses will not update, they update fine using the tuya integration and original firmware.
Anybody have any idea how I could track the dimmer commands from RF or AC Push button I have an isolated TTL adaptor and an untouched original firmware dimmer module with the TX and RX traces soldered to wires for sniffing?
Opening the power strip I found that a Tuya custom CB2S ESP is built in instead of the expected TYWE2S (ESP02S), which apparently comes without the GPIO needed for the boot options. Has someone found in the meantime a way to flash this chip with ESP Home using an UART/USB Adapter, or is it still required to replace it with an ESP02S?
Especially as I did not find a ESP02S on Aliexpress shipping to Germany…
according to the datasheet of the CB2S and connected them to my USB to TTL connector with RX and TX crossed over. At this point a red LED on the power strips PCB started flashing.
Following I pressed “Programm” and connected CEN pin on the CB2S briefly to GND, but the tool did not establish a connection.
@T1ppes for me, it takes several tries with CEN resetting to get bkWriter or hid_download_py to work. It’s tricky, you have to connect CEN to gnd for a certain amount of time, I don’t know, half a second.
I mostly just reboot device with power line instead of using CEN.
Some new information: OpenBeken is now multiplatform and supports also W800/W801 platform with OTA.
So, to sum up, it works on BK7231T, BK7231N, XR809, BL602, and W801/W800 (also on T34 which is just a Beken die in extra casing)
Has anyone already tried the “openbk7231T_App” with Moes MS-104?
After changing the UART converter I have managed to flash. But I have only managed to configure the relay by configuring it on pin24. The switch, I still haven’t managed to make it work…
Would anyone know anything else?
Don’t complicate yourself more… I bought another 340G UART adapter.
It is already installed and working!
Now the only thing left for me to solve is that if it restarts it maintains the state. That takes a couple of nights appearing lights on!
another thing i have checked is that the relay is configured as inverted.
So when on screen is On. It really is off.
Any way to reverse this?
