yes, you can change in pin configuration “Relay” to “Relay_n”. You can also take a look at YAML because older versions used to invert payload_on and payload_off if I remember correctly.
Btw, OpenBeken update - now, previously mentioned, W800 tutorial/article is released (with OTA). Again, flashable by UART.
W800/W801 by Winner Micro, here is photo:
I don’t get any luck to flash the openbeken software to the chip as is. So I am willing to replace the ESP with a ESP02S, but cannot find any on AliExpress that deliver to Germany. Any suggestions on where to find this chip?
To be honest, I have not tried. The instructions in the Git are not very self explainatory.
In the meantime I managed to install Pyhton. But I have no idea on where to extract the downloaded zip file to and where to go from there. The instructions say I should extract them to “%PATH%”. Where exactly is that? I have multiple PATH variables set on my Windows.
Then I should rund “install.bat”, the zip file does not contain a batch file…
Where exactly can I find a python executable of this Been flashing tool? May be that I am blind but haven’t seen anything, I was just trying to follow the steps provided in the Gits read me…
I bought some WiFi power monitoring smart plugs and want to install ESPHome, but it has the a LA-WE2S module with a TR6260S1 chip, so can not be flashed. The product spec states that “The TYWE2S module compatible with pin2pin graffiti”. I want to transplant with a TYWE2S and the dimensions are identical but it only has 1Mbyte flash memory.
I am a total newbie at this. It appears Pins 05, 12 & 14 on TYWE2S are different to the LA-WE2S to the 22, 1 and 0 respectively. Does anyone know if I could use it and would it work? Any assistance would be appreciated.
For anyone interested in non-ESP chips, I will just say that our guides list for BK7231/BK7231T/BK7231N/XR809/BL602/W600/W800/BL602 and much more has reached over 300 entries:
Every entry is a tutorial/guide, sometimes more or less advaned, showing how to flash multiplatform IoT firmware (OpenBeken) to those chips. All chips I mentioned in this post are supported.
We are also working on flashing guides Youtube playlist:
I have motor valve with Tuya CBU chip.I want to flash buth cant go in flashing,usb ttl just ding,ding,ding cant recogniseand openbeken flasher dont recognise. So i just desolder and add D1 mini
