Unkown tuya chip
tuya energy monitor plug board: cb2s
Esphome code
substitutions:
  devicename: tuya20a # ${devicename}
  voltage_divider: "806.1586102719033"
  current_resistor: "0.001067391066279705"
  current_multiply: "0.4406190321602622"
esphome:
  friendly_name: tuya-20a
bk72xx:
    board: cb2s
    framework:
      version: dev
      options:
        LT_AUTO_DOWNLOAD_REBOOT: 0
status_led:
  pin: P8                          # P8 WifiLED //Синий светодиод
binary_sensor:
  - platform: gpio
    name: Button $devicename
    pin:
      number: P10                  #  кнопка P10 Btn (канал 1)
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      - switch.toggle: relay
  - platform: status
switch:
  - platform: gpio
    pin: P26                        # P26 Рел (канал 1)
  - platform: restart
  - platform: hlw8012
    model: BL0937
    current_resistor: ${current_resistor}
    voltage_divider: ${voltage_divider}
    sel_pin:
      number: P24               #  P24 BL0937SEL
      inverted: True
    cf_pin:
      number: P7
      inverted: True            # P7 BL0937CF
    cf1_pin:
      number: P6
      inverted: True            # P6 BL0937CF1
    current:
      accuracy_decimals: 1
      filters:
        - multiply: ${current_multiply}
    voltage:
      #accuracy_decimals: 0
    power:
      filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
      unit_of_measurement: kW
    energy:
      filters:
        # Multiplication factor from Wh to kWh is 0.001
        - multiply: 0.001
      unit_of_measurement: kWh
    update_interval: 8s
    #voltage_divider: 1538
  - platform: wifi_signal
    name: "$devicename WiFi Signal"
    update_interval: 60s
  - platform: uptime
    name: ${devicename} Uptime Sensor
    update_interval: 30s
text_sensor:
  - platform: libretiny
    version:
      name: LibreTiny Version $devicename
  - platform: version
    name: "${devicename} ESPHome Version"
  - platform: wifi_info
    ip_address:
      name: "IP ${devicename}"
    ssid:
  - platform: debug
    reset_reason:
      name: "${devicename} Reset Reason"
So after a lot of search and finding i manage to flash Open Beken on Zmai 90 and is work nice:
To succesfully flash need to desolder RN8209 and after this all is clear:
If you saw in this picture RN8209 is exactly near my solder cable , and template for Open Beken is like this:
  "vendor": "Tuya",
  "bDetailed": "0",
  "name": "Full Device Name Here",
  "model": "enter short model name here",
  "chip": "BK7231N",
  "board": "TODO",
  "flags": "0",
  "keywords": [
    "TODO",
    "TODO",
    "TODO"
  "pins": {
    "6": "WifiLED_n;0",
    "7": "Btn;0",
    "14": "BridgeREV;0",
    "16": "BridgeFWD;0",
    "26": "LED_n;0"
  "command": "backlog startDriver Bridge; startDriver RN8209; PowerSave 1; startDriver NTP; ntp_setServer 93.190.144.3; ntp_timeZoneOfs +2; SetupEnergyStats 1 60 60;",
  "image": "https://obrazki.elektroda.pl/YOUR_IMAGE.jpg",
  "wiki": "https://www.elektroda.com/rtvforum/topic_YOUR_TOPIC.html"
And this is command to start when boot or restart:
How did you open this plug? did you break?
Can someone please help me here? Can these be flashed with Tasmota?
I have 4 curtain switches like these.
Thank you!
It’s an ESP02 so shouldn’t be an issue to flash with either Tasmota or ESPhome
Found another Version of MOES Smart Switch Modules: WM-104B-M
It is very tiny:
40x40 mm and comes with a railmount kit (also screwable).
But it contains also an CB2S…
I ordered some WT32c3-01n:
for replacement.
Hopefully this will works.
Not sure about the powermeter. We will see.
Some more details:
You can flash with esphome now, lots of progress for beken chip since the last 2 years. Unless you need to flash tasmota
