Any support / templates / guides on a dashboard? I would LOOOVE to get rid of glance and it’s docker.
I haven’t thought about dashboards yet but you will be able to create something similar or better with the integration.
I have two UNRAID servers in the house. Has this Integration been tested with two servers on the same network?
It may just be my lack of experience with HA. But when I try and rename the Device only some of the entity IDs get renamed at the same time.
binary_sensors seem to have the Server name, but sensors don’t. As the above image is from my second server being added, they all get a “_2” just stuck on the end of the sensor name. Would be neater if they had similar naming to the binary_sensors.
Any way to fix that? Or do I have to rename all 15 by hand?
I definitely second this!
I have only tested on my unraid server. When I get some free time I will look into implementing a fix.
Thanks. I’ll try and watch out for updates and check them out for you.
I get unavailable for all entities for all 3 unraid servers
Any errors in home assistant logs?
Your UPS doesn’t have the NOMPOWER attribute. Without it the sensor won’t work.
I replied to your GitHub post
That’s unfortunate.
As a workaround, I put a Kauf smart plug in front of the UPS.
I’ll be releasing an update soon to address the naming and re-naming of unraid entities.
This may be a slightly noobish question. Or slightly off thread…
Is there a way to force a status update when an event happens?
I want to make a HA automation that basically says:
“if server fails to respond to ping, update HA-UNRAID status”.
if (binary_sensor.unraid_server = “disconencted”) then (refresh ha-unraid state of that server)
Is there an action I can add to make that happen?
Extra details waffle…
I have pings on a fast rate to check state of servers in my house, but ha-unraid is on a much lower refresh rate. I’d like to be able to do an “update now” command to ha-unraid in case HA sees a ping fail.
I thought of this when I had a power cut this week. Kinda funny to sit in a dark house with the PC still running and online. It was a good test of my shutdown automations.
When my UNRAID server shut down correctly this was reflected in HA’s ping check. BUT ha-unraid was not aware things had changed.
This is why I’ll like to be able to nudge ha-unraid to check when something like this occurs.
You can try this action
UNRAID: Force Update
To find the Config ID you would
Go to Settings → Devices & Services → Unraid
Click on your device entity
Click on UNRAID under Device Info
The URL will show:
/config/integrations/integration/unraid_[entry_id] -
Use the ID after
unraid_in your service calls -
Example URL:
/config/integrations/integration/unraid#config_entry/1234abcd5678efgh -
Your entry_id would be:
1234abcd5678efgh
Excellent. I like that. I’ll give it a go for certain.
Thanks a lot @ruaandeysel
It would be awesome to have HASS Unraid entities for:
- array status (parity check, data rebuild, etc.)
- notifications for alerts, warnings
- last parity check and result
- plugin updates
- interface speeds (snmp?)
- drive temp for array and cache drives
I will replicate this post as a github feature request as well.
Is there a way to use this integration so that when the UPS attached to Unraid cleanly shuts the server down and then normal power is restored to the UPS and not using the battery Home Assistant can turn the Unraid server back on using something like wake on lan?
For example; automation that checks if UPS is using the battery, if yes don’t use wake-on-lan integration to wake up Unraid, if it’s using mains power, send a magic packet using wake-on-lan integration.
Edit: I just realised this probably isn’t going to work as HA isn’t going to know the status off the UPS (battery or mains power) if Unraid is off. I only want to turn Unraid on if the UPS is using mains and no longer using battery.
If we can leverage an entity for the UPS current/power input level or battery remaining level, we can trigger on that and then script the shutdown sequence. I know I have this configured within my unraid interface to automatically shut down when there’s 5 minutes remaining on the battery.
All you need is one machine that comes back and can look at it’s own UPS state. For example, check the HA UPS. If it is charging then you can likely trust there is power in the rest of the house.
I would tend to wait “If HA UPS charging for 15mins, then I can trust house power”. Then fire the WOL packets out to other machines once you trust house power.
I’ve got a Pi 5 I can use as a secondary machine. It can’t check the UPS state if Unraid is shutdown though, can it? My UPS is plugged into Unraid and is set to shut down Unraid when power is switched to the UPS battery for 3 minutes. I was going to use the Pi to send a magic packet to the Unraid server when power is restored. I’m having trouble figuring out how it can check if power is restored when the UPS is plugged into the Unraid server for communication and it’s shut down.
Maybe I should have HA manage the UPS instead of Unraid? See if I can get NUT working on a Pi and integrate with HA that way?
