I’ve got the following issues appearing after the upgrade to 2022.11
Please advise how to fix.
that last one is easy – edit your configuration.yaml file and remove the mqtt: block
try clicking on the others to get more information
Yeah, the last one seems to be trivial, already did the fix.
Docker - I did what was recommended and it disappeared.
And regarding the former three issues - I have no clue.
Operating system says it should be Debian, OK, I’m on Ubuntu since 2018, no problems. Should I ignore it?
Systemd Journal Issues - The systemd-journal-gatewayd
service needs to be running on the host and exposed to supervisor via unix socket.
I never experienced this notice before.
Unsupported Software - Remove any additional software (including standalone containers) you have installed on your host and restart the Supervisor.
A-ha, very funny
see this discussion:
and this issue:
I am spinning in circles.
I have installed everything several times, enabled, started, rebooted, started again - the error message remains. In the meantime the Journal Gateway Service is running, but my system is still unsupported. It is just as BebeMischa described it.
I had same issues, and I solved them with:
sudo apt-get install systemd-journal-remote -y
and
sudo apt --fix-broken install
then
sudo reboot
What does this command exactly do?
In fact,
when I applied the first command, it told me to do: sudo apt --fix-broken install
I did, and finaly it solved my docker troubles
I had no such message, but gave it a try now: returned that there’s nothing to do.
Well… running ubuntu you have been unsupported for a year or so just didn’t realise it before I guess.
I think the fix for the systemd recommends reinstalling? That’s what I did and it fixed everything up without losing anything.
HA has screwed anyone over who is running any other containers as well. I am unhealthy and unsupported. You CAN set HA to ignore unhealthy so you aren’t blocked from updating and you can ignore unsupported with no ill effects.
Now that I recall, it had me do that as well
Well, after I presumably fixed Unhealty system - Docker misconfigured by adding
"log-driver": "journald"
to daemon.json
apparently the message disappeared.
After a while I got new (now - critical) issue:
which is described as below:
So, is this really critical or can be ignored?
Just in case - all my docker containers are running well & healthy.
Also on Ubuntu for years, now 22.04. You may be running into this: CGroup Version - Home Assistant
To use cgroup v1 you can:
- edit /etc/default/grub
- add
systemd.unified_cgroup_hierarchy=0
to GRUB_CMDLINE_LINUX update-grub
- reboot
This didn’t make any noticeable difference for me other than “docker info” shows Cgroup Version: 1
I found this thread looking for a way to perma-ignore the “Unsupported system” notices. I have 2, one for Operating System, and one for Unsupported software for a rogue nginx container I setup.
I can ignore them and they go away, but they come right back after restarting hassio-supervisor. I’m looking for something along the lines of ha jobs options --ignore-conditions unsupported
but that doesn’t seem to be a thing. Anyone know of other ways?
Just ignore it. That’s what I do
I like staying current so the orange badge on the settings icon bugs me
thats helped mi a lot with debian
Hi, can you let me know how to do that? I’ve been stuck on version 2022.11
from the cli
ha jobs options --ignore-conditions healthy
