Unused entities not available
I am using Lovelace and the latest Hass.io version but the option in the top right corner to see the unused items is not showing these items it only shows a white screen. Can anyone tell me how to solve this problem?
Thanks.
Have you tried CTRL+F5 ?
Yes, but refreshing the page does not work! Still blank!
Same over here. Happened to me after the 0.88 update.
Unfortunately 0.88.1 isnā€™t available as a docker image yet. So Iā€™m not
sure if the error occurson that also.
Itā€™s Lovelace related. I started going through my UI config and commenting out anything that was custom and it was the first component, a dual thermostat component. If removing custom ones doesnā€™t work, bisect the config until you narrow it down?
I changed the lovelace mode and restarted Hassio, after restart I could see the unused items again.
Thank you, this helped me get my ā€œunused entitiesā€ page working again
Well - it didnā€™t solve anything for me switching from and to Lovelace UI
Well now I have found root cause: https://github.com/atomic7777/atomic_calendar/issues/62
I have always wondered why I couldnā€™t see any unused entities in Lovelace Configure UI - now I have removed cards one by one from my UI and after removing my ā€˜custom:atomic-calendarā€™ Unused entities appeared again :frowning:
Hello. Looks like no only that component ā€˜custom:atomic-calendarā€™ . I never had it, but I experienced same issue. Unused entities disappear and what ever I tried I cant get it back. I already deleted all custom components besides HACS and switch from and back to Lovelace mode. Anything else I can try?
