Up Bank Integration (Australian Neobank) - Node-Red w/ Home Assistant
Here in Australia one of our neobanks, Up, recently released an API. It seemed like a fun weekend project to get it integrated into my Home Assistant/Node Red setup. I’m still learning the ropes with all these systems, so wanted to share what I’d done to help other Up users and get some feedback on my setup. I hope I’ve managed to make the core functionality really easy to deploy for anyone using HA/NR.
The first step is to register for the Up API and obtain your bearer token. Their guide gives steps on doing this with curl, I used Postman, you can do this however you like. If you want to use webhooks, you’ll need to register your webhook endpoint via the Up API, also following the steps in their guide. My flow uses “/api/up” for the endpoint but you can use whatever you want. The webhook is optional though, you can rely exclusively on the inject node for periodic updates if you prefer.
Then you’ll need to deploy the following NR flow, and put your bearer into the Set Bearer and Inject Bearer nodes.
      "id":"d7911825.3f6ad8",
      "type":"http in",
      "z":"1a80a0df.9dc3ff",
      "name":"Up Webhook",
      "url":"/api/up",
      "method":"post",
      "upload":true,
      "swaggerDoc":"",
      "x":110,
      "y":80,
      "wires":[
            "53dfbba1.6f7794",
            "43a8fb96.292274",
            "9fbed058.18f4c"
      "id":"53dfbba1.6f7794",
      "type":"http response",
      "name":"HTTP  Res",
      "statusCode":"",
      "headers":{
      "x":330,
      "y":80,
      "wires":[
      "id":"43a8fb96.292274",
      "type":"debug",
      "name":"Webhook Debug",
      "active":true,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"true",
      "targetType":"full",
      "x":350,
      "y":40,
      "wires":[
      "id":"9fbed058.18f4c",
      "type":"change",
      "name":"Set Bearer",
      "rules":[
            "t":"set",
            "p":"payload.bearer",
            "pt":"msg",
            "to":"up:yeah:YOURBEARERHERE",
            "tot":"str"
      "action":"",
      "property":"",
      "from":"",
      "to":"",
      "reg":false,
      "x":110,
      "y":120,
      "wires":[
            "bc8e510a.051df"
      "id":"db8688c.78b8878",
      "type":"inject",
      "name":"Inject Bearer",
      "topic":"",
      "payload":"{\"bearer\":\"up:yeah:YOURBEARERHERE\"}",
      "payloadType":"json",
      "repeat":"60",
      "crontab":"",
      "once":true,
      "onceDelay":0.1,
      "x":120,
      "y":200,
      "wires":[
            "bc8e510a.051df"
      "id":"bc8e510a.051df",
      "type":"function",
      "name":"Create Request",
      "func":"msg.headers = {\n    \"Authorization\": \"Bearer \" + msg.payload.bearer\n}\n\nreturn msg;\n\n",
      "outputs":1,
      "noerr":0,
      "x":120,
      "y":160,
      "wires":[
            "dcac08db.5827c8",
            "6df2aa1c.339524"
      "id":"dcac08db.5827c8",
      "type":"http request",
      "name":"Requesting  Balances",
      "method":"GET",
      "ret":"obj",
      "paytoqs":false,
      "url":"https://api.up.com.au/api/v1/accounts",
      "tls":"",
      "proxy":"",
      "authType":"",
      "x":360,
      "y":120,
      "wires":[
            "b9239811.41a128",
            "e581b9dc.690de8"
      "id":"6df2aa1c.339524",
      "name":"Request Transactions",
      "method":"GET",
      "ret":"obj",
      "paytoqs":false,
      "url":"https://api.up.com.au/api/v1/transactions",
      "tls":"",
      "proxy":"",
      "authType":"",
      "x":360,
      "y":160,
      "wires":[
            "b9239811.41a128",
            "e581b9dc.690de8"
      "id":"b9239811.41a128",
      "type":"join",
      "name":"",
      "mode":"custom",
      "build":"array",
      "property":"payload",
      "propertyType":"msg",
      "key":"topic",
      "joiner":"\\n",
      "joinerType":"str",
      "accumulate":false,
      "timeout":"",
      "count":"2",
      "reduceRight":false,
      "reduceExp":"",
      "reduceInit":"",
      "reduceInitType":"",
      "reduceFixup":"",
      "x":590,
      "y":160,
      "wires":[
            "163d9ac.639fe65"
      "id":"163d9ac.639fe65",
      "type":"function",
      "name":"Create Account Name Array",
      "func":"msg.acctNameIndex = {\n    \"acct1\": {\n        \"id\": msg.payload[0].data[0].id,\n        \"name\": msg.payload[0].data[0].attributes.displayName\n    },\n    \"acct2\": {\n        \"id\": msg.payload[0].data[1].id,\n        \"name\": msg.payload[0].data[1].attributes.displayName\n    },\n}\n\n\nreturn msg;\n ",
      "outputs":1,
      "noerr":0,
      "x":380,
      "y":200,
      "wires":[
            "577763df.17851c"
      "id":"577763df.17851c",
      "type":"function",
      "name":"Append Acct Names to Transactions Loop",
      "func":"for (i = 0; i < 19; i++) {\n\nif (msg.payload[1].data[i].relationships.account.data.id == msg.acctNameIndex.acct1.id) {\n  msg.payload[1].data[i].acctName = msg.acctNameIndex.acct1.name;\n} else if (msg.payload[1].data[i].relationships.account.data.id == msg.acctNameIndex.acct2.id) {\n  msg.payload[1].data[i].acctName = msg.acctNameIndex.acct2.name;\n} else {\n  msg.payload[1].data[i].acctName = \"Error\";\n}\n\n}\n\nreturn msg;",
      "outputs":1,
      "noerr":0,
      "x":480,
      "y":240,
      "wires":[
            "cde892e9.a3f6d",
            "dc80980b.90e738",
            "f5cb89bb.4fa188",
            "18507de1.38bf82",
            "95d1ec6d.a99c5",
            "70580ffc.43591",
            "adfb6c91.38004"
      "id":"e581b9dc.690de8",
      "name":"",
      "statusCode":"",
      "headers":{
      "x":590,
      "y":120,
      "wires":[
      "id":"cde892e9.a3f6d",
      "type":"ha-entity",
      "name":"Up Balance 1",
      "server":"788025f4.1f0d8c",
      "version":1,
      "debugenabled":false,
      "outputs":1,
      "entityType":"sensor",
      "config":[
            "property":"name",
            "value":"Up Balance 1"
            "property":"device_class",
            "value":""
            "property":"icon",
            "value":"mdi:piggy-bank"
            "property":"unit_of_measurement",
            "value":"AUD"
      "state":"payload[0].data[0].attributes.balance.value",
      "stateType":"msg",
      "attributes":[
            "property":"displayName",
            "value":"payload[0].data[0].attributes.displayName",
            "valueType":"msg"
            "property":"accountType",
            "value":"payload[0].data[0].attributes.accountType",
            "valueType":"msg"
            "property":"currencyCode",
            "value":"payload[0].data[0].attributes.balance.currencyCode",
            "valueType":"msg"
            "property":"balance",
            "value":"payload[0].data[0].attributes.balance.value",
            "valueType":"msg"
      "resend":true,
      "outputLocation":"",
      "outputLocationType":"none",
      "inputOverride":"allow",
      "x":840,
      "y":40,
      "wires":[
            "9fa1be87.aed34"
      "id":"f5cb89bb.4fa188",
      "type":"ha-entity",
      "name":"Up Transaction 1",
      "version":1,
      "outputs":1,
      "config":[
            "property":"name",
            "value":"Up Transaction 1"
            "value":""
            "property":"icon",
            "value":""
      "state":"payload[1].data[0].attributes.amount.value",
      "stateType":"msg",
      "attributes":[
            "property":"status",
            "value":"payload[1].data[0].attributes.status",
            "valueType":"msg"
            "property":"amount",
            "value":"payload[1].data[0].attributes.amount.value",
            "valueType":"msg"
            "property":"description",
            "value":"payload[1].data[0].attributes.description",
            "valueType":"msg"
            "property":"message",
            "value":"payload[1].data[0].attributes.message",
            "valueType":"msg"
            "property":"foreignAmount",
            "value":"payload[1].data[0].attributes.foreignAmount",
            "valueType":"msg"
            "property":"settledAt",
            "value":"payload[1].data[0].attributes.settledAt",
            "valueType":"msg"
            "property":"createdAt",
            "value":"payload[1].data[0].attributes.createdAt",
            "valueType":"msg"
            "value":"payload[1].data[0].attributes.amount.currencyCode",
            "valueType":"msg"
            "property":"acctName",
            "value":"payload[1].data[0].acctName",
            "valueType":"msg"
      "resend":true,
      "x":850,
      "y":120,
      "wires":[
            "9fa1be87.aed34"
      "id":"dc80980b.90e738",
      "type":"ha-entity",
      "name":"Up Balance 2",
      "version":1,
      "outputs":1,
      "config":[
            "property":"name",
            "value":"Up Balance 2"
            "value":""
            "property":"icon",
            "value":"AUD"
      "state":"payload[0].data[1].attributes.balance.value",
      "stateType":"msg",
      "attributes":[
            "value":"payload[0].data[1].attributes.displayName",
            "valueType":"msg"
            "value":"payload[0].data[1].type",
            "valueType":"msg"
            "value":"payload[0].data[1].attributes.balance.currencyCode",
            "valueType":"msg"
            "value":"payload[0].data[1].attributes.balance.value",
            "valueType":"msg"
      "resend":true,
      "x":840,
      "y":80,
      "wires":[
            "9fa1be87.aed34"
      "id":"9fa1be87.aed34",
      "type":"debug",
      "name":"Up Debug",
      "active":true,
      "tosidebar":true,
      "console":false,
      "tostatus":false,
      "complete":"true",
      "x":1120,
      "y":160,
      "wires":[
      "id":"18507de1.38bf82",
      "type":"ha-entity",
      "name":"Up Transaction 2",
      "version":1,
      "outputs":1,
      "config":[
            "property":"name",
            "value":"Up Transaction 2"
            "value":""
            "property":"icon",
            "value":""
      "state":"payload[1].data[1].attributes.amount.value",
      "stateType":"msg",
      "attributes":[
            "value":"payload[1].data[1].attributes.status",
            "valueType":"msg"
            "value":"payload[1].data[1].attributes.amount.value",
            "valueType":"msg"
            "value":"payload[1].data[1].attributes.description",
            "valueType":"msg"
            "value":"payload[1].data[1].attributes.message",
            "valueType":"msg"
            "value":"payload[1].data[1].attributes.foreignAmount",
            "valueType":"msg"
            "value":"payload[1].data[1].attributes.settledAt",
            "valueType":"msg"
            "value":"payload[1].data[1].attributes.createdAt",
            "valueType":"msg"
            "value":"payload[1].data[1].attributes.amount.currencyCode",
            "valueType":"msg"
            "value":"payload[1].data[1].acctName",
            "valueType":"msg"
      "resend":true,
      "x":850,
      "y":160,
      "wires":[
            "9fa1be87.aed34"
      "id":"95d1ec6d.a99c5",
      "type":"ha-entity",
      "name":"Up Transaction 3",
      "version":1,
      "outputs":1,
      "config":[
            "property":"name",
            "value":"Up Transaction 3"
            "value":""
            "property":"icon",
            "value":""
      "state":"payload[1].data[2].attributes.amount.value",
      "stateType":"msg",
      "attributes":[
            "value":"payload[1].data[2].attributes.status",
            "valueType":"msg"
            "value":"payload[1].data[2].attributes.amount.value",
            "valueType":"msg"
            "value":"payload[1].data[2].attributes.description",
            "valueType":"msg"
            "value":"payload[1].data[2].attributes.message",
            "valueType":"msg"
            "value":"payload[1].data[2].attributes.foreignAmount",
            "valueType":"msg"
            "value":"payload[1].data[2].attributes.settledAt",
            "valueType":"msg"
            "value":"payload[1].data[2].attributes.createdAt",
            "valueType":"msg"
            "value":"payload[1].data[2].attributes.amount.currencyCode",
            "valueType":"msg"
            "value":"payload[1].data[2].acctName",
            "valueType":"msg"
      "resend":true,
      "x":850,
      "y":200,
      "wires":[
            "9fa1be87.aed34"
      "id":"70580ffc.43591",
      "type":"ha-entity",
      "name":"Up Transaction 4",
      "version":1,
      "outputs":1,
      "config":[
            "property":"name",
            "value":"Up Transaction 4"
            "value":""
            "property":"icon",
            "value":""
      "state":"payload[1].data[3].attributes.amount.value",
      "stateType":"msg",
      "attributes":[
            "value":"payload[1].data[3].attributes.status",
            "valueType":"msg"
            "value":"payload[1].data[3].attributes.amount.value",
            "valueType":"msg"
            "value":"payload[1].data[3].attributes.description",
            "valueType":"msg"
            "value":"payload[1].data[3].attributes.message",
            "valueType":"msg"
            "value":"payload[1].data[3].attributes.foreignAmount",
            "valueType":"msg"
            "value":"payload[1].data[3].attributes.settledAt",
            "valueType":"msg"
            "value":"payload[1].data[3].attributes.createdAt",
            "valueType":"msg"
            "value":"payload[1].data[3].attributes.amount.currencyCode",
            "valueType":"msg"
            "value":"payload[1].data[3].acctName",
            "valueType":"msg"
      "resend":true,
      "x":850,
      "y":240,
      "wires":[
            "9fa1be87.aed34"
      "id":"adfb6c91.38004",
      "type":"ha-entity",
      "name":"Up Transaction 5",
      "version":1,
      "outputs":1,
      "config":[
            "property":"name",
            "value":"Up Transaction 5"
            "value":""
            "property":"icon",
            "value":""
      "state":"payload[1].data[4].attributes.amount.value",
      "stateType":"msg",
      "attributes":[
            "value":"payload[1].data[4].attributes.status",
            "valueType":"msg"
            "value":"payload[1].data[4].attributes.amount.value",
            "valueType":"msg"
            "value":"payload[1].data[4].attributes.description",
            "valueType":"msg"
            "value":"payload[1].data[4].attributes.message",
            "valueType":"msg"
            "value":"payload[1].data[4].attributes.foreignAmount",
            "valueType":"msg"
            "value":"payload[1].data[4].attributes.settledAt",
            "valueType":"msg"
            "value":"payload[1].data[4].attributes.createdAt",
            "valueType":"msg"
            "value":"payload[1].data[4].attributes.amount.currencyCode",
            "valueType":"msg"
            "value":"payload[1].data[4].acctName",
            "valueType":"msg"
      "resend":true,
      "x":850,
      "y":280,
      "wires":[
            "9fa1be87.aed34"
      "id":"788025f4.1f0d8c",
      "type":"server",
      "z":"",
      "name":"Home Assistant",
      "legacy":false,
      "addon":false,
      "rejectUnauthorizedCerts":true,
      "ha_boolean":"y|yes|true|on|home|open",
      "connectionDelay":true,
      "cacheJson":true
Once deployed, if Home Assistant is properly connected to Node Red, you should see some sensors in HA with details in the attributes:
Once these appear, create a group in groups.yaml:
up_transactions:
  name: Up Transactions
  entities:
    - sensor.up_transaction_1
    - sensor.up_transaction_2
    - sensor.up_transaction_3
    - sensor.up_transaction_4
    - sensor.up_transaction_5
Once grouped, create a Lovelace card by copying this yaml into a Manual card:
cards:
  - content: '## Up Bank'
    type: markdown
  - cards:
      - detail: 2
        entity: sensor.up_balance_1
        graph: line
        hours_to_show: 72
        icon: 'mdi:cash'
        type: sensor
      - entity: sensor.up_balance_2
        graph: line
        hours_to_show: 72
        type: sensor
    type: horizontal-stack
  - content: >
      #### Recent Transactions:
      {% for transaction in states.group.up_transactions.attributes.entity_id
      {# Check if more than one day old, and apply formatting #}
      *{%- if ((as_timestamp(now()) -
      as_timestamp(state_attr(transaction,"settledat"))) / 60 / 60 / 24) |
      round(0) > 0 -%}
        {{ ((as_timestamp(now()) - as_timestamp(state_attr(transaction,"settledat"))) / 60 / 60 / 24) | round(0) }} day
          {#- Pluralise if not 1 -#}{% if ((as_timestamp(now()) - as_timestamp(state_attr(transaction,"settledat"))) / 60 / 60) | round(0) != 1  %}s{%- endif -%}
      {# Check if more than one hour old, and apply formatting #}
      {%- elif ((as_timestamp(now()) -
      as_timestamp(state_attr(transaction,"settledat"))) / 60 / 60) | round(0) >
      0 -%}
        {{ ((as_timestamp(now()) - as_timestamp(state_attr(transaction,"settledat"))) / 60 / 60) | round(0) }} hr
          {#- Pluralise if not 1 -#}{%- if ((as_timestamp(now()) - as_timestamp(state_attr(transaction,"settledat"))) / 60 / 60) | round(0) != 1  -%}s{%- endif -%}
      {# Otherwise, format age for minutes #}
      {%- else -%} {{ ((as_timestamp(now()) -
      as_timestamp(state_attr(transaction,"settledat"))) / 60) | round(0) }} min
      {%- endif %} ago*
      {# Print amount value with bold formatting #}
      **${{- state_attr(transaction,'amount') | float | abs -}}**
      {# Change language for positive/negative #}
      {%- if state_attr(transaction, 'amount') | int  > 0 -%}
         came into
      {%- elif state_attr(transaction, 'amount') | int  < 0 -%}
         went out of
      {%- endif -%}
      {{- state_attr(transaction,"acctname") }}
      {{ state_attr(transaction,'description') }} {{
      state_attr(transaction,'message') }}
      {% endfor %}
    type: markdown
type: vertical-stack
The result should look like this:
The webhook is very convenient for any kind of notifications you might want to integrate. This next example is a lot more dependent on my particular light/speaker configuration and won’t be as easy to drop into an existing config, but should show how simple it is to connect webhooks to a notification system.
Had to remove the code to fit within the character limit, but if anyone is interested I’ll put this flow in a Pastebin or something.
Love this!
I might try to tackle the same thing without NR (I don’t use NR for my automations).
Argh we need some NZ banks to get on board with this kind of thing!!!
Thanks for this- looks awesome. I’m looking forward to setting it up
I know this is an old thread, but seams to be the only one about Up.
Ive created a python integration for HA for Up, so no node red needed.
Thanks @Nassau for this great node red flow, your node-red version still has more features than mine does, but easier to set up for most people, and planning to add more features. Seeing this node red flow inspired me to do one in python
Thanks @Nassau this is fantastic, and it worked more or less out of the box for me. I am not using it with HA yet, just wanted to get the data out into NR.
I did do things like dynamically name the accounts depending on how many there are, and stripped the silly emoji’s out of the name.
just wanted to give you some kudos for your work.
