Marnik
(Marnik Vanhilderson)
November 23, 2023, 4:06pm
1
Home assistant installed on raspberrypi.
I try to install latest update but failed 3 times.
Next is what i find in the logs.
23-11-23 16:25:58 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2023.11.3
23-11-23 16:25:58 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.11.2 to Package raspberrypi3-64-homeassistant · GitHub
23-11-23 16:25:58 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package raspberrypi3-64-homeassistant · GitHub with tag 2023.11.3.
23-11-23 16:26:03 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.11.3/json: Internal Server Error (“readlink /mnt/data/docker/overlay2: invalid argument”)
23-11-23 16:26:03 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
herbus
(JosH)
November 25, 2023, 10:02pm
2
I’ve the same issue. Can’t find the solution
PigCon
(Pig Con)
November 26, 2023, 5:35pm
3
Here’s pondering on the exact problem also.
erik7
(Erik)
November 26, 2023, 5:45pm
4
Reboot your system and try again.
It’s most likely (not enough) memory issue Rpi3.
It looks like I have a similar issue but on initial installation of HA on Raspeberry Pie 3B (1GB ram) . The installation failed on this error page:
Error installing Home Assistant
An error occured while installing Home Assistant, check the logs below for more information.
herbus
(JosH)
November 26, 2023, 9:39pm
6
I run HA on a Intel NUC, don’t think the resources are the issue here
I redid the whole installation process, exactly same steps and that time it worked…
catch-33
(Catch33)
November 27, 2023, 2:32pm
8
Had the same problem.
It seems one of the docker images was corrupted.
I was able to fix it by running
ha supervisor repair
After that the 2023.11.3 update went through normally for me via the GUI.
Be careful though as the repair option might mess with docker images you have installed manually and are not managed by HA…
cheers!
herbus
(JosH)
November 27, 2023, 3:55pm
9
catch-33:
Thank you very much!!! That solved the issue. I’ve updated to 2023.11.3 now.
catch-33:
I get this message
supervisor.docker.interface] Can’t install ghcr.io/home-assistant/qemux86-64-homeassistant:2023.11.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2023.11.3&fromImage=ghcr.io %2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("error creating temporary lease: read-only file system: unknown
Can anyone advise how to solve this?
