This happened to me last week when I attempted to update the system to 2022.3.3. The error I got was “Your installation is running in an unhealthy state.” The issue with the 2022.3.3 update was documented here:
and here:
In an attempt to troubleshoot I thought the prudent thing to do a full restore of a Google backup from 3 days prior. Everything loaded properly except for the Smartthings integration.
After the 2022.3.3 issues were resolved I tried installing it (and 2022.3.4) but the Smartthings integration is still unavailable with the following errors:
Error setting up entry Home for smartthings
March 12, 2022, 1:05:22 PM – (ERROR) components/smartthings/__init__.py
Error processing webhook
This whole issue was pretty frustrating considering I had a simple Home Assistant Blue setup and I took precautions with backups. Now my automations and lovelace UIs are in disarray with all these unavailable devices.
Is my only solution to start over with the Smartthings integration? From what I understand I have to run some sort of javascript to nuke the unavailable devices from my Home Assistant instance. This is going to be a PIA because I’ve created new entities such as grouped shades from Smartthings devices and then programmed those new entities into other platforms such as my Logitech Harmony remote.
Also, can someone explained to me why this happened based on the steps I took?
